Author Topic: Number plate lights clanking around!?  (Read 1435 times)
Offline f1fan
« on: February 24, 2013, 09:50:23 pm »
I bought a pair if 18 SMD LED number plate lights this week. They are sealed units that replace the existing VW units.
However they also have an extra wire running to a silver metal block.  When I fitted them I had to poke the block in first and let in find its own path then the light.
Took the care for its first drive tonight since fitting them and can hear a strange metallic clanking noise, I'm guessing the blocks and bouncing around in the bumper.
Any one else had this problem and how did you fit the metal blocks?
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
Re: Number plate lights clanking around!?
« Reply #1 on: February 24, 2013, 11:37:13 pm »
Mine didn't come with any.  :surprised:
One of the othet forumites did.
Offline chrisr763
  • -Receive: 62
« Reply #2 on: February 24, 2013, 11:40:11 pm »
The silver block is the resistors I presume. Have you tried the lights without the reistors attached? Do they stay on for more than 5 seconds?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: February 25, 2013, 11:33:09 am »
Yep that will be the resistors, i'd suggest "no more nails" type tape and try and fix the resistor into the recess first
Offline f1fan
« Reply #4 on: February 25, 2013, 01:25:18 pm »
I wondered if I could stick the resistors to the top of the light unit itself, not sure if there is enough vertical clearance.  Other I'll try sticking them to the inside of the bumper before putting the light in.
Offline CAPTAIN BRITAIN
« Reply #5 on: February 25, 2013, 03:36:41 pm »
I'm using the same 18 smd units without the resistor little silver box and they have worked perfectly for the last year i had them fitted, i say unclip it see how you get on.
The units themselves are not a perfect fit, But they don't rattle either
Offline f1fan
« Reply #6 on: February 25, 2013, 04:45:54 pm »
So, daft question I know, but what exactly do the resistors do if you can run the lights ok without them??
« Reply #7 on: February 26, 2013, 06:18:04 pm »
I think resistors are used so that it adjusts the leds to your cars voltage so that you don't get the bulb warning light,
But the number plate lights never give a bulb out warning so the resistors are not needed,
Someone correct me if I'm wrong about the job of a resistor.
Offline f1fan
« Reply #8 on: February 26, 2013, 06:35:31 pm »
They've stopped clunky around now, maybe they have fallen off!!  :grin:
I didn't get bulb failure warnings off the old bulbs so as you say probably don't need them.  Will try it out.
Offline chrisr763
  • -Receive: 62
« Reply #9 on: February 27, 2013, 08:14:37 am »
Number plate bulbs are not read so no warning lights. However! If the led causes little resistance then they may turn off after 5 seconds...hence the need for the resistors. But try without :)
Offline f1fan
« Reply #10 on: March 31, 2013, 10:15:00 am »
I eventually managed to fish the silver blocks out from inside the bumper and removed them.  The lights work perfectly without them so I'm not putting them back in, obviously no error warnings as you mentioned.
Just need to change the number plates to pressed metal ones now  :happy2:
