Author Topic: Car totally dead - no electrics  (Read 5325 times)
Offline em2evol
  • Let's Motorvate!
« on: March 04, 2013, 02:00:48 pm »
Got in my car this morning and when I turned the key, the dials lit up for a second then went dead, then it just made a clicking noise, there was no power anywhere - I had to lock the car using the key in the lock… But it had unlocked on the button fine...
I last used the car on Saturday and I only ever do short journeys (2-5 miles) - VW have told me over the phone today that the battery is dead because I don't use the car enough, but I find it hard to believe it can just go from being perfectly fine with no signs of a flat battery to having no electrics whatsoever... Is this really likely to be the case, or could it be something else?
Thanks a lot,
Em
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Car totally dead - no electrics
« Reply #1 on: March 04, 2013, 02:01:48 pm »
Changed the headunit?
Diesel Daily Hack.
Offline 56OctyVRS
  • -Receive: 72
« Reply #2 on: March 04, 2013, 02:08:29 pm »
Batteries are funny things and can collapse without warning. Id get it jump started and get a garage to do a load test to check the health of the battery.
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #3 on: March 04, 2013, 02:12:04 pm »
Does your battery have an indicator on it?  Should be Green. Easy to flatten a battery if your not charging it.
The headunit issue is a problem on the newer gen HU's: RCD/RNS 310/510 in older cars (sub 2008 iirc), you will need either need a new headunit or upgrade the gateway.
So, question is, what model year is your car, and what headunit do you have?
Offline bacillus
  • -Receive: 453
« Reply #4 on: March 04, 2013, 02:19:50 pm »
I vote for charging the battery and look for a hidden current draw before renewing it.
Offline em2evol
  • Let's Motorvate!
« Reply #5 on: March 04, 2013, 07:17:48 pm »
Thanks all. I jump started the car and took it for a long drive tonight so we'll see what happens tomorrow morning!  :driver:
Offline camfollower
  • -Receive: 31
« Reply #6 on: March 04, 2013, 09:54:51 pm »
No report on year of car or model of headunit!?
« Last Edit: March 05, 2013, 04:08:21 pm by camfollower »
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: March 05, 2013, 03:33:22 am »
Sounds like the battery is on the way out to me.
Offline andygo
« Reply #8 on: March 05, 2013, 03:56:05 pm »
Battery is there, its the electrickery thats gone.
Offline em2evol
  • Let's Motorvate!
« Reply #9 on: March 05, 2013, 08:22:49 pm »
So I bought a new battery today and for the first time in months my stereo came on when I turned the ignition on, horay! Problem seems to be fixed... Perhaps I should just use my heated seats a bit less if I'm doing only 4 miles a day  :rolleye:
Offline andygo
« Reply #10 on: March 05, 2013, 09:10:47 pm »
Offline Trev.
« Reply #11 on: March 06, 2013, 11:17:25 am »
If your only doing 4 miles a day the heated seats will drain the battery more than its charging haha, so yeh not using them is a good start!
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #12 on: March 06, 2013, 01:13:56 pm »
.......thought that would cure it. :innocent:
