Author Topic: Brake Disc Hub Rust (Looking to paint)  (Read 18978 times)
Offline Kalpsn2000
  • -Receive: 56
« on: March 11, 2013, 01:33:15 pm »
Hey guys/gals
I got my NQSBBK fitted a couple of weeks (and absolutely love it :smiley:) but the brake disc hubs have started to rust (I have now read it is common). So I plan to paint them during the bank holiday later this month, so I wanted to find out what paint is best to get.
I'm thinking of going for silver or black.
What paint would you guys/gals recommend?
Kalpesh
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Brake Disc Hub Rust (Looking to paint)
« Reply #1 on: March 11, 2013, 01:39:48 pm »
Sand back, rust remedy, etch primer, then high temp paint... I've always done silver, but black looks good...
Diesel Daily Hack.
Offline will_15
« Reply #2 on: March 11, 2013, 01:40:47 pm »
Painted mine with Black Hammerite 'Direct to Rust' stuff from Halfords, did the same with my previous 2 cars where the same thing had happened!
« Reply #3 on: March 11, 2013, 02:46:21 pm »
Did all mine before having them fitted the other day. No pics of the rears but they look like the fronts. I used Zinc 182 Anti rust primer followed by Halfords Black High Temperature Paint. I masked everything off but i was told this is not really needed as the pads will remove any excess paint/spray. 2 coats of each (both sides) and the edges.
« Last Edit: March 11, 2013, 03:01:10 pm by MC71 »
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: March 11, 2013, 02:58:37 pm »
D'oh! Should have done that before fitting (you live and learn). I think I will have to do it with them fitted to the car now, so probably best to go for brush on rather than spray I'm guessing.
Martin do you have any pics of them fitted to the car? I was leaning towards silver but may go for black depending on the look.
« Reply #5 on: March 11, 2013, 03:03:55 pm »
^^^^ no pictures that show the painted areas I'm afraid. Maybe when it stops snowing here!  :grin:
Offline Kalpsn2000
  • -Receive: 56
« Reply #6 on: March 11, 2013, 04:25:15 pm »
No worries. Yeah we have had some here in London but not settling.
Anyone else got any pics showing black brake disc hubs?
homesqueeze
« Reply #7 on: March 11, 2013, 08:13:40 pm »
Here you go! I did mine last year using Halfords high temperature satin black paint. Brushed it on whilst hubs were on the car. Easy enough to do and looks good.
Offline Kalpsn2000
  • -Receive: 56
« Reply #8 on: March 11, 2013, 10:56:28 pm »
Thanks mate :happy2:
So that's another job for the holiday added to the list.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #9 on: March 11, 2013, 11:03:29 pm »
I have to get this done too. The laziest option seems to be - brush off loose rust then a lick of Hammerite 'direct to rust'.
If I make a bags of it it's no big deal as I'll have to replace the discs soon enough anyway.
'07 Red manual
Offline Kalpsn2000
  • -Receive: 56
« Reply #10 on: March 12, 2013, 10:58:09 am »
That's what I am currently planning to do :smiley:
Am looking to go silver so would this be ok?
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_158822_langId_-1_categoryId_255239
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #11 on: March 12, 2013, 11:02:03 am »
Is there any heat tolerance in that paint?  I know this isn't going to generate as much heat as the disc/pad surface, but I'd bet it gets pretty hot at times; last thing you want is that dripping on to your wheels... or disc/pad! :surprised:  I like the idea of matching the disc colour though. :smiley:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #12 on: March 12, 2013, 11:11:53 am »
It's not specifically a high temperature paint. However some forum people have used it without issue.
Actually I was thinking of using it on my calipers, but not sure if they get hot or not??
'07 Red manual
Offline camfollower
  • -Receive: 31
« Reply #13 on: March 12, 2013, 11:21:47 am »
Probably a good couple of hundred degrees C for the calipers (don't quote me) - I'd only use high temp. paint on those personally - there's lots of caliper paints in halfords.  Thinking about, I'd probably use some caliper paint on the bells too.
Offline coolhandluke
  • -Given: 28
« Reply #14 on: March 12, 2013, 12:30:01 pm »
Can I ask what colour are your wheels,smoked chrome or anthracite?
