Author Topic: Removing intake.  (Read 4330 times)
Offline Andy_Ed30
Removing intake.
« on: March 14, 2013, 12:29:21 pm »
The sound of the evoms is starting to get annoying.  The only time I like it is at full throttle, The rest of the time it just sounds crap.
Do you guys think I will lose much power removing my evoms intake and putting the standard air box back on with a aftermarket panel filter.
I have edition 30 with a stage 1 map
The car made 286bhp on the rollers @ JKM.
Thanks andy.
Offline bacillus
  • -Receive: 451
Re: Removing intake.
« Reply #1 on: March 14, 2013, 01:09:54 pm »
You will lose some hp but gain a little more low end torque if you go back to the oem air box.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #2 on: March 23, 2013, 02:53:01 am »
Andy, agree with bacillus.
To minimize that small loss of power even more I'd recommend to remove the lip inside the small box behind the grill.
Remove the cover/cap and you'll see what I mean.
there:
this lip:
removed:
smoothened:
Before this most of the air went into the engine bay.
BTW, I'd go for an OE paper filter.
"You get what you pay for."
Offline MizGTi
« Reply #3 on: August 16, 2013, 07:54:16 am »
Very handy post. Was just considering a EVOMs intake. Need to look elsewhere. Thanks
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #4 on: August 16, 2013, 08:57:36 am »
The tolerance level of the intake noise is all down to personal preference though I think, you have to expect an increase in noise from any induction kit. I quite enjoyed the chatter from my Evoms, the Twintake made a lot more whooshing though.:happy2:
Offline kahunajb
« Reply #5 on: August 19, 2013, 07:01:18 pm »
there:
this lip:
removed:
smoothened:
Bruce what did you use to smooth it? I presume it needed plastic welding?
05 Laser Blue Mk5 GTI - Revo Stage 1
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=dipiibhsltmm1se7k5et21881a&/topic,19740.0.html
« Reply #6 on: August 19, 2013, 08:38:22 pm »
The removal and smoothing of that lip will make approximately 0.000000000% power increase!  :P
Offline Markyed30
« Reply #7 on: August 19, 2013, 11:01:59 pm »
The evoms sounds fine!!! Man up  :signLOL:
« Reply #8 on: August 19, 2013, 11:40:09 pm »
^^^ THis... an not to mention the ~20bhp peak power increase!
Offline xjay1337
  • -Receive: 377
« Reply #9 on: August 20, 2013, 12:24:06 am »
If it doesn't Rich, I'm going to come to your freshly redecorated bathroom and poopy on it!!
Offline MizGTi
« Reply #10 on: August 20, 2013, 10:37:03 am »
Just got into a friends car who has a EVOMs intake and i can see why you like the noise. I think it sounds great. If u had to recommend one which would it be? My choices are between the EVOM and the Twintake. Opinions would be greatly appreciated.
Offline MizGTi
« Reply #11 on: August 20, 2013, 10:37:11 am »
« Reply #12 on: August 20, 2013, 12:55:26 pm »
Evoms for goes.... Forge for shows.  :signLOL:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #13 on: August 20, 2013, 12:55:41 pm »
If you've got a GTI (non Ed30/ Pirelli) then either of the two should work great, I know the Twintake made good gains on my bf's GTI but it was rubbish on my Ed30...
Saintsteve
« Reply #14 on: August 20, 2013, 09:36:50 pm »
But it's ok on mine though  :drinking:
 :signLOL:
