Author Topic: RNS 510 v9 Delay  (Read 6842 times)
Offline Demonter
RNS 510 v9 Delay
« on: March 15, 2013, 11:46:40 am »
Hi guys.
Im new here and before I represent myself I need your help.
I have Passat CC with RNS 510 and i Have installed V9 maps.
I had V3 before (2008/09 model)
It took my about 4hrs to install it. The main problem is that Once it was done Ive noticed delay or lag. Icon on
map was about 2-3sec after my real position. I couldnt fix it anyhow and so I did factory reset on the rns device.
Now I will try to install it once more time. any Ideas what went wrong or what should I do next time?
Offline Kiwi
Re: RNS 510 v9 Delay
« Reply #1 on: March 15, 2013, 12:27:19 pm »
What firmware is on the unit ? As that'll make the difference on speed........................  :driver:
Offline Demonter
« Reply #2 on: March 15, 2013, 02:54:38 pm »
I have no idea dude,neither I know how to check it? Im kinda noob for it.
all I know is car is 2009 model registred in november 2008 for the first time. Never been touched in that technical matter. only service intervals etc. Its the first time now Ive been trying to install something.
Offline Kiwi
« Reply #3 on: March 15, 2013, 03:01:10 pm »
Here you go, this explains all  http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
Basically the firmware does the running of the unit, and the maps are an App that loads on top.
Offline Demonter
« Reply #4 on: March 15, 2013, 03:16:18 pm »
yes ive been reading that post this morning but one thing confuses me. there is several ...X firmware links listed periodically which means I should ddl latest one (381x)?? and what does A B C unit means?
Offline bacillus
  • -Receive: 451
« Reply #5 on: March 15, 2013, 03:29:07 pm »
It's the hardware revision of the unit...
Offline Demonter
« Reply #6 on: March 15, 2013, 04:37:33 pm »
i see...
is there any chance i can see unit version i have? coz all i can see when i hold settings button is this
is there way i can see maps version that are installed atm?
this is how my unit looks like
ive been reading alot about some vcds diagnostics that might help with entering secret menu but have no ida what is it
« Last Edit: March 15, 2013, 05:31:39 pm by Demonter »
Offline hardhat
« Reply #7 on: March 15, 2013, 07:09:14 pm »
 Hi, I was in your position, got my local dealer to look for the info on their computer. (did it for free!)
 Get in touch with vw55raz off here, he helped me sort it out.  :happy2:
Offline Demonter
« Reply #8 on: March 15, 2013, 07:25:25 pm »
tnx for posting m8. my brother was king with this stuffs but he died in car accident for 3months ago so im on my own.
Im croatian but i live n sweden,these sweds are nuts. dude in service tald me 200-250€ for fixng it.
will cotact that user as soon as i get option of msging. im tired of sh*t
« Last Edit: March 15, 2013, 07:33:56 pm by Demonter »
Offline bacillus
  • -Receive: 451
« Reply #9 on: March 15, 2013, 07:56:33 pm »
Try keeping the set up button pressed for 30 seconds to access the hidden menu.
If it doesn't show up then you'll need vcds to adapt channel 50 for your sat nav to enable the function.
Offline Demonter
« Reply #10 on: March 15, 2013, 08:37:50 pm »
setup button doesnt work been pressing whole afternoon. what is vcds? :ashamed:
Offline bacillus
  • -Receive: 451
« Reply #11 on: March 15, 2013, 09:39:37 pm »
Image borrowed from the for sale forum item.
Offline Demonter
« Reply #12 on: March 18, 2013, 02:28:14 pm »
ok guys Ive been at local servis and I did check up on my device. I took this pic and this is all info I could get from the dude.
It stands device unit but not sure if there is software version.
Whic SW do you recomend I should Install, that works properly with v9 7918 without problems on the sound, batery drain etc???
Offline Kiwi
« Reply #13 on: March 18, 2013, 04:06:25 pm »
You can go up to firmware 3810, without any issues on your H/W
1T0 035 680 B from software version 1000, 800,  900, 1100 , 2660 and 2700 to version 3810  :happy2:
Where you based? as someone local may have the firmware on Disc you could borrow
Offline Kiwi
« Reply #14 on: March 18, 2013, 04:10:01 pm »
The new features are :-
Voice Control (requires microphone – see Volkswagen RNS 510 Microphone Connection for voice control)
NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
NEW Compass
NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
NEW Languages – Arabic,  Russian, Turkish and Polish
Speed Limit Display
Stability Improvements
Faster Startup (this has been improved on 2720)
Display OPS and RVC at the same time
SDHC 32 GB Support (HW04 and above)
Display Off on extras tab
Climatronic control if approriate climatronic fitted
Clock display if RNS 510 swtiched off
Excluded roads (under route options)
GPS coordinates entry
Additional adjustments for video
Larger RVC screen with transparent menus at the side
