Its aliveeeee!!!!!
This is the first start, pretty impressive how quickly it fires hey! All seems perfect, was struggling to hold an idle due to the DV not being routed back into the intake, so the MAF readings will have been all over the place..
Few bits and bobs to do now..
* Tidy up a couple of bits in the engine bay
* Fit PCV system
* Finish intake and DV pipe work
* Fit brakes
* Set suspension up
* Fit seats and sort out the interior
* Go for the first drive and take some logs!!
That should all be done around lunch time so then I can get some miles onto it!
Sounds absolutely amazing!! You can tell its been played with put it that way!!
Ill get a proper update up tomorrow with the finished build pics and some first impressions!!
