Author Topic: YELLOW ENGINE SIGN ON REV COUNTER - RANDOM  (Read 1777 times)
Offline Rustybear
  • -Given: 243
« on: March 25, 2013, 05:34:05 pm »
Yellow engine sign came on out of the blue this morning. Car is running fine, no lumpty ness, pulls well etc. Having had coil problems on my mk4 when I saw this sign I know its not coil packs (plus they have been changed by VW as a recall), however, having had a TT this sign came on when a problem with exhaust sensor of some sorts so I just wondering if this could be a same issue on Golfs Gti's or if I can check anything else i.e. MAF, lamba sensor etc as  i don't have VAG com thing to tell me but don't really want a bill from VW for checking out and giving fault code.
Re: YELLOW ENGINE SIGN ON REV COUNTER - RANDOM
« Reply #1 on: March 25, 2013, 05:35:13 pm »
Did it flash a few times and then go out?
It could have been a misfire.
Offline Rustybear
  • -Given: 243
« Reply #2 on: March 25, 2013, 07:41:38 pm »
Na. Just came on when I started the car back up after a five min school run this morning @ 9ish and stayed on ever since :(
Offline PDT
  • -Receive: 142
« Reply #3 on: March 25, 2013, 07:44:03 pm »
Look in the vagcom section for a friendly local cable owner.
homesqueeze
« Reply #4 on: March 25, 2013, 07:55:49 pm »
I've had this a couple of times. It is indeed to do with exhaust/emissions, that's what it says in the handbook anyway. First time it didn't go away and the dealer checked and reset it and said there were no problems. Second time it went away by itself after a couple of days. I think it can be down to filling up with a dodgy batch of fuel.
« Reply #5 on: March 25, 2013, 08:02:13 pm »
The light will disappear after a certain number of ignition cycles for certain faults.
Trying to guess what it is is pointless as it can come on for a multitude of faults. Get it scanned.
Offline alexmccabe
    • Alex McCabe
« Reply #6 on: March 26, 2013, 09:06:44 am »
Mine just turned on after a long drive, luckily my friend was on the way home, he took a peek and there was pretty much nothing of importance on the scanner. I expected as much as the car drove fine like yours. After he cleared all my codes, the light disappeared and hasn't come back.
MK5 Golf GTi 197BHP Tornado Red
Offline Rustybear
  • -Given: 243
« Reply #7 on: March 26, 2013, 10:59:35 pm »
Thanks all!!! :happy2:
 Managed to get to friends garage who have Vag thing, fault was air flow sensor. Unplugged, wiggled a bit, blew it, put back, checked again fault gone along with dash sign!!!  :laugh:
Offline Rustybear
  • -Given: 243
« Reply #8 on: March 29, 2013, 12:29:18 am »
It's back so looks like I need to get the part replaced etc. looking at the engine bay front on it's the part connected to air flow pipe drivers side with two Torx screws and has a bit that you clip in/out. Before I make a ... Of myself what's this part MFW???
« Reply #9 on: March 29, 2013, 12:33:19 am »
MAF is circled yellow.
Remove the elec. clip and 2 torx screws and pull it out.  :happy2:
