Author Topic: Have I been done by the spray shop?  (Read 4199 times)
Offline GeeJay
« on: March 30, 2013, 07:14:59 pm »
Hi all,
So after posting here about a DIY bumper paint and being talked out of it, I took my bumper to the spray shop to be painted Wednesday late evening.
Got a call Friday lunch to pick it up, nice and quick I thought.
Basically - I was gently trying to fit it and some paint started flaking and it looks to me like there is no primer...what do you think? This won't last two minutes.
Opinions on what is actually on the bumper? Primer? Paint? Lacquer?
Where do I go from here, I haven't contacted the spray shop about it yet.
Any help appreciated, I paid £130 for it to be painted :(
The bottom two are of the masking tape that the headlight washer bits were stuck to. I see no primer or lacquer on there? On the bottom pic I have lifted some paint and turned it over - looks metallic blue on the back to me...!
This is black ABS plastic showing, looks silver due to flash. Bumper was brand new:
« Last Edit: March 30, 2013, 08:22:08 pm by GeeJay »
Offline MickMc
Re: Have I been done by the spray shop?
« Reply #1 on: March 30, 2013, 07:21:47 pm »
Going by the first pic , i assume the bumper was originally silver ? if so , they have simply sprayed the base/clear over the original paint. They should have flattened it back to give it a key and applied the top coats (no need for primer if the bumper was originally painted and not plastic)
Offline GeeJay
« Reply #2 on: March 30, 2013, 07:23:27 pm »
Nope, a brand new ABS plastic bumper that was black.
Offline MickMc
« Reply #3 on: March 30, 2013, 07:24:14 pm »
in the first pic , is it silver under the paint or plastic (but showing silver due to flash on camera ?)
Offline GeeJay
« Reply #4 on: March 30, 2013, 07:28:36 pm »
Black plastic. I'll get some better more pics in natural light in the morning.
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: March 30, 2013, 07:31:36 pm »
Thats a hidden part of the bumper so prob didn't get primed and paited the same as the visible part of the bumper.  Give them a call to confirm.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: March 30, 2013, 07:32:01 pm »
Hand it back to be fixed correctly or ask for your money back  :stupid:
Silver is the way !
Offline MickMc
« Reply #7 on: March 30, 2013, 07:32:55 pm »
Alex , he has said the bottom pics are masking tape that was on the headlight washer , if thats the case , i'd say the whole bumper will be the same (i.e. no primer)
I'm going to take a guess and say they sprayed the plastic primer over it (or maybe not) and then done the base/clear. It should have been given a key > plastic primer > primer > base/clear . I'd be having words with them
Offline gizm0
« Reply #8 on: March 30, 2013, 07:33:28 pm »
That definitely hasn't been keyed correctly before it was painted, and I'd day it hasn't been primer edshould have been done with a plastic primer and fully keyed to help the paint stick and stop it flaking like that, once you get one stone chip the rest will start flaking off. Take it back to the body shop and get a refund and take it elsewhere.  I wouldn't trust them again if they can't even do a simple bumper spray
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: March 30, 2013, 07:33:59 pm »
I would be ringing them to double check and explain what you have found!
Offline GeeJay
« Reply #10 on: March 30, 2013, 08:21:48 pm »
One more photo. This lifted from fitting flex alone, so I picked it to see behind:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #11 on: March 30, 2013, 08:31:18 pm »
That's an absolutely terrible job. Go and give them grief and get it done properly or get a full refund.
'07 Red manual
Offline vRSAlex
  • -Receive: 253
« Reply #12 on: March 30, 2013, 11:00:43 pm »
Yeah thats a poor show.
« Reply #13 on: March 30, 2013, 11:21:27 pm »
ask them to do it again
Offline Draz1k
« Reply #14 on: March 31, 2013, 09:33:17 am »
Where was the garage that you used?
