Author Topic: What brake discs for s3 brake setup  (Read 6562 times)
Offline vag12
« on: April 09, 2013, 02:31:30 am »
I changed by discs about two months ago from euro car parts and found out the are awful and judder violently when braking from high speeds, can anyone recommend me anything else that can actually handle the heat lol
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: What brake discs for s3 brake setup
« Reply #1 on: April 09, 2013, 07:00:05 am »
渵怋奷閹滀磠冱一絓赽倬姁仨峓屮,楢絭屮秅盻楀侘帄乇昍蓒袀圠坭。焥攽伓蕖瑂嶴价一菀淖悜侕玊氠乜,嫊嵉屮冼壴裬枍宄亍耵蝁毘夃岪。夃倧芢偤秏纗睟滏庄忔柧芅弢枌戺敯屮岝朅頏。尐淯姇婕砉瓥嫈獉阠伓峊杚泙芴狁蜌兀玢銙亃。覂一苠偢趄葔丌榤獥勼,埽兀侳袸惲鉯屮漰殳犰。埡一峈掑覕趎丌輍頲旡,梒乜玴偞湆搢乇牄仉刉。勼埒佶徖胘灠葙葅扤邔炟毐旻彾忺溳乜屇僓鉏。
« Reply #2 on: April 09, 2013, 08:19:01 am »
I am sorry Dave, it does not matter one iota whether you prefer Chinese Lesbians to the European type. You can still only wear 6 inch heels when out on a date with either. Hope this helps.  :happy2:
Offline bacillus
  • -Receive: 451
« Reply #3 on: April 09, 2013, 08:22:44 am »
What pads are you using?
  • Trader - 2014
  • -Receive: 130
« Reply #4 on: April 09, 2013, 08:42:58 am »
TC your mandarin needs looking at....
Was just explaining the warranty procedure.....
Allegedly the "Pagid" de-icer they sell isn't up to much either....
Think we'll have this branding arrangement for another 18 months yet
Back on topic.....  As the good doctor says what pads are you using?
Offline xjay1337
  • -Receive: 377
« Reply #5 on: April 09, 2013, 09:42:54 am »
I very much doubt it's the heat, have you checked your pistons to ensure they are free moving and not sticky?
Did you replace the pads at the same time?
Standard OE brake discs are the best and then some quality pads and fluid on top of that.
« Reply #6 on: April 09, 2013, 09:57:27 am »
Im not sure what discs mine are (daveb will be able to tell you). They are drilled and they have had tons of abuse on the road... and they have worn perfectly, no warping.
I presume the ones bought were cheapo discs... ?
« Reply #7 on: April 09, 2013, 12:55:19 pm »
Go to VW/Audi and buy the OEM discs.
I currently have some drilled and grooved discs that DaveB supplied to the original owner of my brakes and with new pads and a slight skim have now lasted the best part of 2 years.
I know Jim @ JKM uses OEM discs on track just with a change of pads to something more exotic.
Yes they weigh the same as a small moon but they are more than capable of with standing some abuse.
  • Trader - 2014
  • -Receive: 130
« Reply #8 on: April 09, 2013, 08:50:41 pm »
Generally they would have been Bremtech - green black box.
OEM would work also but only available plain discs of course.
Offline gazbutS3
« Reply #9 on: April 09, 2013, 10:23:31 pm »
I've had trouble with 2 sets of ECP "pagid" discs and pads on my daily Bora TDI now, and won't be going near them again. Not sure if its warped discs or pad deposits causing bad vibration but I should have learnt the first time  :smiley:
Offline xjay1337
  • -Receive: 377
« Reply #10 on: April 10, 2013, 12:25:40 am »
If you really want something that's reasonably priced and work well, I've used M-tec brakes before, they provide discs, you can either have them plain, drilled, grooved, drilled AND grooved or slotted. Plus you can get some pretty funky coatings as well in terms of a black or silver coating, to prevent rust.
I think it's around £125 delivered for a set of pads with a coating. Not bad really, worked well on my old 280mm setup.. arguably under a lot more stress than my 345s.
Offline adgti
« Reply #11 on: April 10, 2013, 12:33:04 am »
Nothing wrong with pagid infact If you compare the Pagid pad's to your OEM pads there exactly the same with all the same numbers on! What does that tell you?
Did you clean the hubs up before putting the new disk on?
Did you give them chance to bed in?
Are your sliders free?
 :jumpmove:
Offline vag12
« Reply #12 on: April 10, 2013, 02:50:32 am »
So someone's saying the pagid parts and OEM is the same with part numbers is that correct? And am using brembo sport pads and bought the discs at the same time, am sure the discs are the problem being cheap as I thought these were the OEM replacemts anyway.
So now I need to to get a proper good set where to?
Offline Beddie
  • -Receive: 76
« Reply #13 on: April 10, 2013, 07:04:43 am »
Whilst Pagid branded items did give some reassurance of oem equivalent quality a few years back sadly nowadays discs / pads via ECP are generic Chinese tat dressed up and sold under the Pagid brand name to which ECP have the sole rights to in the UK, as DaveB has already said they use the Pagid name on air freshener and screenwash too..
I've had juddering/fade issues with a set of EPC 'Pagid' discs for my S3 setup as have many others on here, before I threw them in the bin I googled the foundry casting marks on the discs and found they were proudly made in china.. No such problems with my 2 subsequent sets of OE discs via the dealer and only £106 inc vat a pair via TPS  :happy2:
Carbon Grey Edition 35 - Here
Offline vag12
« Reply #14 on: April 10, 2013, 11:47:33 am »
Well that's excellent I will be getting my next set from dealers, other them OEM are there any updated options out there slotted/drilled and where to get them from?
