April 24, 2025, 05:29:44 pm
General
Random Chat
PolarFIS+ Advanced : New Update v0.3.7 [09-04-2013]
Topic: PolarFIS+ Advanced : New Update v0.3.7 [09-04-2013] (Read 1113 times)
bacillus
Just look at my post count
-Given: 4
-Receive: 451
April 09, 2013, 06:14:11 pm »
***** Improvements / Update description for RED cluster *****
Fixed problem with reading parameter "Ignition Angle" and "Angle Delay", by which did not display negative values
Fixed problem with Parktronic OPS where vehicles with front and rear sensors, would not start by pressing the activation Parktronic
Fixed problem with Parktronic OPS which did not work for volume reduction in the RNS-510
Fixed problem with Parktronic OPS by which did not work in some vehicles Skoda
Fixed problem with Parktronic OPS by which did not display front sensor values in some vehicles Skoda
Improved compatibility with the emulation function of BT white FIS with steering wheel installed on red FIS vehicles
Improved Italian, Portuguese and Polish translations
Fixed windows rise up to enable automatic closing of windows
Fixed problems with some diagnostic functions, giving the message FUNCTION NOT AVAILABLE
Fixed issue that caused the automatic shutdown settings windows, One touch opening, and emulation climatronic
Added parameter DPF (miles traveled since last regeneration)
***** Improvements / Update description for WHITE and COLOR cluster *****
Improved PolarFIS power off
Added DPF parameter (Miles traveled since last regeneration)
For install this update, please use ActiveX from our official web
www.auto-polar.com
(Update Zone)
bacillus
-Given: 4
-Receive: 451
Re: PolarFIS+ Advanced : New Update v0.3.7 [09-04-2013]
Reply #1 on:
April 11, 2013, 04:14:25 pm »
Well I'm happy to report that with this firmware the RNS510 Parktronic OPS emulation finally works.
Matto
-Given: 24
-Receive: 116
My Ride:
Reply #2 on:
April 11, 2013, 07:32:10 pm »
Have you tried the Climatronic emulation? I misread your last post thinking that was what you meant so been out to try it. It doesn't log any faults now when its enabled but the only one to show on the RNS is for the heated rear screen.
GT Sport Progress Thread
My Door Lock Module Replacement DIY
bacillus
-Given: 4
-Receive: 451
Reply #3 on:
April 11, 2013, 07:54:51 pm »
I've only updated this afternoon with the car in the garage so haven't checked if Climatronic emulation actually works on a Golf.
afaik it only works in a Skoda but who knows...
General
Random Chat
