Author Topic: Cheap mandrel bending sheffield area?  (Read 1339 times)
Offline tommygti
  • -Given: 22
« on: April 16, 2013, 07:42:04 pm »
Anyone know of anywhere in the sheffield region that does cheap mandrel bending? Cheers
Offline PDT
  • -Receive: 142
Re: Cheap mandrel bending sheffield area?
« Reply #1 on: April 18, 2013, 06:56:14 pm »
Exhausts uk  :happy2:
Offline tommygti
  • -Given: 22
« Reply #2 on: April 18, 2013, 07:05:11 pm »
All ready tried. I need a ss 25mm tube mandrel bend and they cant bend anything of that small diameter. Cheers anyway
Offline Edition30
« Reply #3 on: April 18, 2013, 10:37:48 pm »
What do you need doing?
Have a section roller at work. Just depends what you need.
MyProtein - MP119633
Offline tommygti
  • -Given: 22
« Reply #4 on: April 18, 2013, 11:19:23 pm »
I need a custom dv relocate pipe made. Similar to eurojets. Only needs 3-4 bend in it but if that is too difficult to do 4 bends all at different angles then I could split the bending into two parts and then weld it together again. I also will need a custom high-flow intercooler to tb pipe bent but that will be 60mm wide ss pipe and requires 1-2 bends.
Similar to these:
