Author Topic: Parrot Mki9200  (Read 3982 times)
Offline Andygolf
Parrot Mki9200
« on: April 18, 2013, 10:28:14 pm »
Hi all I am looking at fitting my parrot mki9200 into my gti this weekend I received my SOT adapter this morning.
I am looking for some advise and hopefully pictures of where everyone has there screen/ adapters fitted.
Also where to wire the ingniton live for this that I keep seeing mentioned. As my mk4 golf was just plug in and go.
Thanks in advance
Andy
Offline paulw123
  • -Receive: 47
Re: Parrot Mki9200
« Reply #1 on: April 20, 2013, 10:19:55 am »
Plenty of you tube videos on this.
&feature=results_main
my 9100 screen is fitted below centre RH air vent, and above radio, the cable goes through corner of where the plastic covers meet.
« Last Edit: April 20, 2013, 10:23:57 am by paulw123 »
Offline Andygolf
Re: Parrot Mki9200
« Reply #2 on: April 20, 2013, 10:23:43 am »
Cheers but I have already watched these and they do not show what I am looking for. Again if anyone has any pictures of where they have there screen and plugs that would be great.
I am looking at fitting mine the the arm rest.
Re: Parrot Mki9200
« Reply #3 on: April 20, 2013, 10:23:49 am »
Thanks in advance
Andy
I installed one of these a few month back... I took a feed off the cigar lighter for the ignition live.
Offline john87
  • -Receive: 53
Re: Parrot Mki9200
« Reply #5 on: April 26, 2013, 10:03:15 am »
I bought my 2008 with one installed by a previous owner..the screen is located above the right hand side air vent, and the remote is behind the drivers' window switches  :happy2:
Offline Andygolf
Re: Parrot Mki9200
« Reply #6 on: April 26, 2013, 11:26:06 am »
Cheers John have you got any pics you could post up ?
Offline Duv
Re: Parrot Mki9200
« Reply #7 on: April 26, 2013, 12:00:47 pm »
i put mine in the middle above screen and ran the input cables to the can holder on the right of the steering wheel.
pic of mine fitted:
MK6 Golf GTI 5 DOOR - Deep Black Pearl - Manual
RCD 510 DAB
17" Monza
Wanted - 3sdm 0.01 18" in black - 5x112
Offline Andygolf
Re: Parrot Mki9200
« Reply #8 on: April 26, 2013, 12:29:44 pm »
pic of mine fitted:
Cheers for that i guess you had to drill a hole to put the screen there?
Offline Duv
Re: Parrot Mki9200
« Reply #9 on: April 26, 2013, 12:36:00 pm »
It's just stuck on with the sticky pads you get with it and then there is a clip out panel just behind for the air vent. I have a spare so made a hole in that at the side and the wire goes down from
There. I also put the microphone in front of the speedo, well next to the fuel gauge. Works really well there. Switched live I got from the cig lighter.
RCD 510 DAB
17" Monza
