Author Topic: MKV Hella Xenon-Look and HID Kit Install (Picture heavy)  (Read 55104 times)
Offline mtj2k
  • 1.4 TSi GT
« on: April 24, 2013, 01:19:12 pm »
Hello all,
I finally bit the bullet and bought a set of Hella "Xenon-Look" headlights and a 6000K HID kit. If anybody's interested i took some pics of the install and some info on what exactly I bought:
Headlights: Purchased from German Carparts GmbH
Part Numbers: 1LL 009 476-031 & 1LL 009 476-041 (RH Drive)
Cost: €342 delivered (Mar13)
HID Kit: Purchased from HID's Direct
Part Numbers: HD822/6k (35W)
Cost: £49 delivered (Mar13)
So, this was my car with the original, silver backed headlights.
I'm not going to explain how to remove the front bumper, too many threads on that and very easy to do - easier with 2 people.
Bumper off, standard lights out:
New Lights:
New lights in with standard bulbs:
Installing the HID kit:
The bulb holders are at a 45degree angle so the HID earthing strip doesnt require the dreaded "6 o'clock" mod:
As if they were designed for HID's no wire splicing required! Don't do what i did, red goes into yellow! BTW you will need to remove the bulb retaining clip to fit the HID kit as the clip goes round the wires.
I chose to stealth mount the ballast on the bottom of the units, where the OEMs should go, the holes lined up perfect, well for two of the three!
Headlights installed, bumper re-fitted, white LED sidelights, job's a fish...
Overall: Very happy, beam output and pattern is immense - sorry i don't have any pics of this yet. But passed MOT last week with them installed. Any questions re supplier or help required PM me. Don't forget to get on VCDS and change to "Xenon's without shutter" to prevent any chance of flickering etc..
Thanks for looking  :happy2:
Offline Kalpsn2000
  • -Receive: 56
Re: MKV Hella Xenon-Look and HID Kit Install (Picture heavy)
« Reply #1 on: April 24, 2013, 01:42:41 pm »
Look brilliant :happy2:
I fitted my Depo Xenon Look lights last weekend (along with a 5k HID kit), love them. Like those sidelight bulbs you have, which ones are they?
Also I haven't done any coding in VCDS. What module will it be under?
Offline mtj2k
  • 1.4 TSi GT
« Reply #2 on: April 24, 2013, 02:28:06 pm »
Thanks, couldn't go back to halogens after driving with these installed. Couldn't tell you what LED's i have, had them for ages, just some cheap eBay jobby. I think it was under Central Electrics:
If you got an oldish VCDS you may not have the option but you can still change it manually see this http://forums.vwvortex.com/showthread.php?3986819-HELP-Xenon-without-shutters-option-not-available-in-VagCom/
Offline xjay1337
  • -Receive: 377
« Reply #3 on: April 24, 2013, 02:43:42 pm »
Hi mate
Out of interest why did you go into Xenon coding and enable Xenons? What difference does that make? I've been running xenons  (Hella Celis) for nearly a two years, without this box checked. Just wondered if it changed the behavior at all.
Offline mtj2k
  • 1.4 TSi GT
« Reply #4 on: April 24, 2013, 02:50:22 pm »
It was more preventative rather than a fix for anything. Research had said some people experienced HID flickering if you didn't enable this. I have VCDS so it was a 5 min job, if i didn't i probably wouldn't have bothered. Like you i had the celis sets on for about a year without this option enabled no problem
Offline Mk5Dom
« Reply #5 on: April 24, 2013, 03:26:46 pm »
Nice work!  :happy2:
Offline rob-gti
« Reply #6 on: April 24, 2013, 04:56:03 pm »
they look smart!! nice job  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: MKV Hella Xenon-Look and HID Kit Install (Picture heavy)
« Reply #7 on: August 09, 2013, 10:14:32 am »
Good guide here mate
Could you tell me which leds you used for the sidelights?  Ive got a set of these headlights coming in and need to get the sidelights changed while the lights are off the car
Sent From My Samsung S3
Offline Matto
  • -Receive: 116
« Reply #8 on: August 09, 2013, 07:26:55 pm »
Nice work. I see you have the newer slimmer ballasts as well. They sent me one of these as a warranty replacement but sent it back. I find that even though they are slimmer, all the boxes on the cables are a complete mess. They sent me an used but working ballast that I could fit where I had previously as the install is a lot neater. Here is a pic showing mine for reference  :happy2:
Offline itismebigd
« Reply #9 on: August 10, 2013, 08:22:11 am »
Hi i have retro fitted oem xenon headlights and had to enable and code them as the op stated they do flicker without doing this well mine did anyway,maybe you have to do this if the headlights are oem hope this helps lol
Dougie :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: August 18, 2013, 09:49:55 am »
Done mine yesterday.  The light output is amazing!  All in with led sidelights come under £290!
Offline torque777
« Reply #11 on: August 18, 2013, 09:20:07 pm »
Is there a link for these headlights ? Thanks
sent using my own fingers
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Offline torque777
« Reply #13 on: August 19, 2013, 06:33:28 am »
Offline swiftlupogti
« Reply #14 on: August 26, 2013, 12:47:14 pm »
Can you still operate the beam height adjuster after fitting these?
