Author Topic: RNS510 - can you add a sub woofer to this stereo?  (Read 1404 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: May 01, 2013, 04:35:36 pm »
As title says, just looking for info and adding a small sub in the back of my MK6 GTI....Thanks
Offline GTI-Ross
Re: RNS510 - can you add a sub woofer to this stereo?
« Reply #1 on: May 02, 2013, 08:51:11 am »
Anyone?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: RNS510 - can you add a sub woofer to this stereo?
« Reply #2 on: May 02, 2013, 08:54:51 am »
Yes you can. You have to get an adapter that converts the wire from the rear speaker to a phone.  That gives the phono outputs.
And the remote wire ive seen people take from the ciggie lighter on a mk5.  Might be different on a mk6. Power and ground to the amp ad normal.  And I think thats it afaik.
Sent From My Samsung S3
Offline Squeeguk
« Reply #3 on: May 04, 2013, 11:22:32 am »
Or you can get a newer amp with high level speaker inputs which also has the effect of being a remote wire too. You just need to make up a harness from the head unit to the amp or cut the existing wiring.
