Author Topic: Can you buy a "Key Shell" ..... DONE!  (Read 3812 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=8ceu8uo0knh95fsbdmm6qkinf2&/topic,19740.0.html
« on: May 06, 2013, 12:48:51 am »
Hi peeps.
The keyring hook part of my keyfob has broken. Is if possible to buy a "shell" and just swap over my internals and key blade?
Rich
« Last Edit: May 09, 2013, 01:51:13 pm by richwig83 »
Offline xjay1337
  • -Receive: 377
Re: Can you buy a "Key Shell"
« Reply #1 on: May 06, 2013, 01:01:42 am »
« Reply #2 on: May 06, 2013, 01:22:29 am »
« Reply #3 on: May 06, 2013, 01:23:59 am »
yes but the transporter in the case is difficult to get out but not impossible--if you break it the car won't start
http://forums.vwvortex.com/showthread.php?2293184-DIY-Key-Fob-Immobilizer-Swap-(yes-it-can-be-done)
« Last Edit: May 06, 2013, 01:29:38 am by maxitrol »
« Reply #4 on: May 06, 2013, 01:42:01 am »
I don't need that bit swapping anyway. Just the back part with the battery in it.  :happy2:
« Reply #5 on: May 06, 2013, 01:59:17 am »
Phew all good then :happy2:
Offline bacillus
  • -Receive: 451
« Reply #6 on: May 06, 2013, 12:27:59 pm »
THanks mate.... went for the slightly more expensive one, supposed to be genuine VW.
http://www.ebay.co.uk/itm/REPLACEMENT-3-BUTTON-FLIP-KEY-CASE-FOR-VW-GOLF-PASSAT-BETTLE-CADDY-REMOTE-KEY-/321065259042?pt=UK_Cars_Parts_Vehicles_Other_Vehicle_Parts_Accessories_ET&hash=item4ac0fb1022
Will let you know how i get on.  :happy2:
At the bottom of that ad does say "Please note this item is as close to the original VW casings as possible in terms of quality and finish" so be forewarned if there's an issue.
« Reply #7 on: May 06, 2013, 02:37:56 pm »
Well if I'm not happy with it ill just send it back  :happy2:
Offline mrbeck
« Reply #8 on: May 07, 2013, 08:03:08 am »
I bought one of these last year and I was really impressed with the quality.  Changing the transponder chip (should you decide to do so) wasn't too bad either.  I just dropped some nail varnish remover on it to dissolve the glue, popped the chip out and then glued it into the new case again.  Job done!
2008 VW Golf GT Sport TSI 1.4 (170PS)
OEM + Cruise Control (Retrofit), R36 Omanyt 18" Alloys, R32 Rear Lights, VW Polo Stubby Aerial, VW Front & Rear Mud Guards, Team Heko Wind Deflectors, Dubmeister Pressed Plates, ABT Wolfsburg Plate Surrounds, Autoform Boot Liner.
Offline ell.s
« Reply #9 on: May 08, 2013, 01:55:52 am »
dont be scared of changing the transponder its a doddle it does come out with little persuasion.
Re: Can you buy a "Key Shell" ..... DONE!
« Reply #10 on: May 09, 2013, 01:54:52 pm »
IMG_2147 by Rich Wigley, on Flickr
IMG_2149 by Rich Wigley, on Flickr
IMG_2150 by Rich Wigley, on Flickr
IMG_2143 by Rich Wigley, on Flickr
IMG_2146 by Rich Wigley, on Flickr
And all fixed....
IMG_2148 by Rich Wigley, on Flickr
Offline arris
« Reply #11 on: May 09, 2013, 06:51:48 pm »
Could do with doing this to one of my keys as the blade like when folded in wobbles loads due to it being worn :(
Glad to see its a good fit!
