Author Topic: retrofit front fogs  (Read 1304 times)
Offline biglad65
retrofit front fogs
« on: May 12, 2013, 12:34:33 pm »
thinking of retrofitting front fogs can anyone tell me what wiring i need from kufatec  its for a standard front end do i need HB4 OR H11 thanks
Offline torque777
Re: Re: retrofit front fogs
« Reply #1 on: May 12, 2013, 01:14:58 pm »
I think early golfs used hb4 in fish eye type fogs and its h11 in the reflector type ...I retro fitted mine and ended up with hb4 ends so had to by a conversion kit from bold-sport.com
sent using my own fingers
Offline biglad65
« Reply #2 on: May 12, 2013, 02:16:40 pm »
some one else as told me i need h11 dont know what to do now im sure eddie-nl would now
Offline torque777
« Reply #3 on: May 12, 2013, 03:21:31 pm »
What fog light you got ?
Offline Action jackson
« Reply #4 on: May 12, 2013, 03:22:55 pm »
I have a set of standard fogs which I could let you have for a few quid. They fit the standard bumper, not gt/Gti
Offline torque777
« Reply #5 on: May 12, 2013, 03:36:14 pm »
These are reflector type I got
Genuine grills
Loom I had made up
Mk6 light switch
Ive got a pdf somewhere with fitting instructions
Offline biglad65
« Reply #6 on: May 12, 2013, 03:41:40 pm »
they are for gti not standard
Offline torque777
« Reply #7 on: May 12, 2013, 03:44:48 pm »
Yes they are but its the same principle ..just different fogs but same loom and relay and switch
Offline torque777
« Reply #8 on: May 12, 2013, 03:47:53 pm »
Well the loom I had made was for hb4 but I fitted later reflector type lights and they were h11 ...if you ring vw and ask what bulb should be fitted to your car with optional fogs fitted they will tell you what should be in as standard then you can order loom to suit
Offline biglad65
« Reply #9 on: May 12, 2013, 04:01:29 pm »
think i got it if you look at the bulb holders the pins are close together with h11 and far apart on hb4 is this right buy yours
« Last Edit: May 12, 2013, 04:03:44 pm by biglad65 »
Offline biglad65
« Reply #10 on: May 12, 2013, 04:29:35 pm »
just had a look at mine and its got a h3 bulb in it now im confused
Offline torque777
« Reply #11 on: May 12, 2013, 04:44:43 pm »
H11 on left (small) hb4 on right (spaced further apart )
Offline biglad65
« Reply #12 on: May 12, 2013, 04:50:10 pm »
thats great thanks
Offline Mk5Dom
« Reply #13 on: May 12, 2013, 05:40:19 pm »
I wouldn't mind looking at this, is there anyway you can PM it to me?
Offline torque777
« Reply #14 on: May 12, 2013, 08:18:01 pm »
Pm me your email and will try 8)
