Author Topic: Radio static..... How to fix?  (Read 6250 times)
« on: May 31, 2013, 04:04:13 pm »
I've got an issue with my car. And I say car as opposed to radio, because this happens with either my MFD2 or Rns510.
The radio is fine when stationary however when moving the radio is affected with a static crackle.
Any other audio source.... HDD/SD etc is unaffected.
Seems to have happened since my throttle body was changed... This might just be a coincidence though.
Any idea to as how to fault find this or how to fix it? To me it looks like an earth issue.
Rich
Re: Radio static..... How to fix?
« Reply #1 on: May 31, 2013, 07:44:45 pm »
Evening, post tea bump.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: May 31, 2013, 07:57:12 pm »
earth strap?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: May 31, 2013, 08:12:32 pm »
I seem to remember its something to do with the signal amplifer in the boot lid. Sure i had it bookmarked. Give me a sec..........
Offline doylebros
« Reply #4 on: May 31, 2013, 08:51:30 pm »
Had the same fault tailgate wiring issue for me.
« Reply #5 on: June 01, 2013, 02:01:01 am »
More info please chaps   :happy2:
Earth strap? Where do I find this?
« Reply #6 on: June 01, 2013, 01:00:57 pm »
Just a bit more info.....
The battery - terminal and earth strap appear to be fine. Is there any point in taking it off?
The static crackle only occurs when the engine is running.... even when stood still.
It does not happen if the engine is switched off OR if the ignition is on.
Any more ideas?
« Last Edit: June 01, 2013, 01:07:08 pm by richwig83 »
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #7 on: June 01, 2013, 01:05:34 pm »
Rich
Alternator needs a suppressor unless its the antenna causing the bad earth.
Does the interference noise increase as you increase the revs?
P
« Reply #8 on: June 01, 2013, 01:08:07 pm »
Rich
P
Its not alternator whine... its not linked to engine speed.
Offline galaxie500
  • -Given: 38
« Reply #9 on: June 01, 2013, 01:31:56 pm »
Poo.
Dunno then. Try Eddie. He'll have the educated answer!
Soz.
« Reply #10 on: June 02, 2013, 09:13:36 am »
Sonntag bumpen  :smiley:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: June 02, 2013, 09:22:40 am »
does it get worse when you switch the rear heated screen on?
Cluster and Key coding
Location Great Yarmouth
« Reply #12 on: June 02, 2013, 09:30:55 am »
Will test that today.
I have an factory fit OEM SatNav roof aerial.. the little short shark fin type one, if that makes any odds.
« Reply #13 on: June 02, 2013, 04:28:51 pm »
Rear demister doesnt make a difference.
Looking in the Setup menu (the hidden one) when looking at the FM option... it keeps going between mono and stereo. I got a video... will post it once my phone turns back on
« Reply #14 on: June 02, 2013, 04:38:54 pm »
Ignore the sound on it....
