Author Topic: Hi Guys Not A MK5 But the running gear is :-)  (Read 4680 times)
Offline fenix
« on: June 03, 2013, 07:10:59 pm »
Hi Guys,
I don't own a MK5 Golf but do have a few other VW's I have a MK1 Jetta, A Mk2 Jetta and a Passat TDI for smoking round in. I have a TFSi Going into my MK1 Jetta with a GT3076 and Full Haldex system so it should be fun. It is Coming along really well. I need to get my posts up now so that I can post in the for sale section. As i Bought an APR GT3071 turbo kit that I don't need as I've gone bigger turbo and BSH tubular manifold that we cut and flipped 180 to fit the big turbo in. I worked out better to bespoke build a kit to the car than chop up a kit that was made for a MK5.
So thats a little about me.
Hi Guys,.
« Last Edit: June 06, 2013, 08:22:45 am by fenix »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Hi Guys Not A MK5 But the running gear is :-)
« Reply #1 on: June 03, 2013, 08:34:44 pm »
Hello mate and welcome to the forum.
The Jetta sounds and interesting project indeed.  :happy2:
Offline fenix
« Reply #2 on: June 03, 2013, 08:55:44 pm »
Thanks, We have over 400 hours in it so far and have quite a way to go.
Offline fenix
« Reply #3 on: June 03, 2013, 09:48:50 pm »
So far we have,
IE Rods,
BHS Manifold modified,
GT3076 Turbo,
Tial 44mm Wastegate,
Full Haldex,
Custom Driveshafts,
Corsa Electric power steering,
MK2 Golf Syncro Tunnel,
Custom Fuel Cell,
Custom fuel filler,
TT 5 speed gearbox with Pelequin diff,
Custom Down pipe and exhaust,
Custom Engine mounts,
AUtotech HPFP,
Spec stage 3+ clutch
Arp fixings throughout.
And more to come. :jumpmove:
« Last Edit: June 06, 2013, 12:13:20 am by fenix »
Offline luke2702
« Reply #4 on: June 05, 2013, 12:04:36 am »
400 hours?? You need to spend more time drinking   :happy2:
On a serious note mate will be a serious stealth mobile when it is complete looking forward to seeing this done.
Offline fenix
« Reply #5 on: June 05, 2013, 06:16:59 am »
Ill post up a build thread if anyone is interested.
Offline torque777
Re: Re: Hi Guys Not A MK5 But the running gear is :-)
« Reply #6 on: June 05, 2013, 06:21:23 am »
Hi and welcome
sent using my own fingers
Offline john a
    • The Veneers Cover Band
« Reply #7 on: June 05, 2013, 09:12:04 am »
Definitely
Offline Neiltdi
  • Full Hex+CAN
« Reply #8 on: June 05, 2013, 09:42:32 am »
Most people cut the scuttle out to smooth there bay , You HAVE to for that massive Turbo!
Cant wait to see more progress on this , finally a real build where its not just swapping nice shiny parts to more nice new shiny parts!
Grinders and welders FTW!
Full Hex+CAN in Hampshire.
Offline fenix
« Reply #9 on: June 05, 2013, 09:51:06 am »
There has been lots of welding for sure, there was the syncro golf floor swap to get the high transition tunnel in. The syncro rear axle to put in and mount plus scrapping the syncro rear diff and welding in a cradle to take the TT rear haldex unit. Cutting the bulkhead and fitting the recess for the turbo.  All the driveshafts had to be welded. Ill put some pictures up later. Should I put them here or is there a separate area for builds?
Thanks for the interest.
Offline chrisr763
  • -Receive: 62
« Reply #10 on: June 05, 2013, 03:38:44 pm »
Sounds very tasty to me, get some pics up of the beautys  :happy2:Wish my turbo could swallow up a coke can!
Offline fenix
« Reply #11 on: June 05, 2013, 07:09:02 pm »
Pictures coming in a mo!
Offline fenix
« Reply #12 on: June 05, 2013, 10:27:49 pm »
Corsa B electric power steering.
The Raw ingredients.
Offline fenix
« Reply #13 on: June 05, 2013, 10:40:54 pm »
The Donor Car.
Offline fenix
« Reply #14 on: June 05, 2013, 10:51:52 pm »
IE Rods installed.
All the harmonic balance weights if you have never seen them.
The manifold mounted as BHS intended.
