So Jonny, what are you up to today with the Eddie?
Today I have mostly been spending money on it lol.. Oh and fit the Red Pro Race wheels back on too..
Having a full day on the car tomorrow to.. Fit VWR Race engine mounts / Light weight battery / Race anti-roll bars / Adjust the suspension and re set-up / take as much weight out as possible from anywhere we can get to!!
Then Wednesday im getting a set of Pole Positions back in it..
Then in a couple of weeks the Race suspension, Aluminum suspension components, Race brakes, Carbon bits should be done.. Which will just leave the challenge of fitting the wide wheels and tyres on it!! I have a feeling that will be a nightmare, I dont want to run anything more than 2.5 degrees negative camber..
I'd love to see the Bildon kit on a white ED30...
I'm sure a decent body shop could get the ED30 front splitter and rear diffuser to fit? All that carbon would surely save weight over adding metal with arch extensions?
I want the car to look as OEM from the outside as possible really.. Not into all the wide arches etc etc.. The front wings will be made from carbon and painted, and the rears will (hopefully) just be pulled, so it will be very subtle when finished.. And should loose weight in the process too..
