Author Topic: Wing mirror removal  (Read 5190 times)
Offline Gez118
Wing mirror removal
« on: June 21, 2013, 10:30:34 pm »
Hi , need some help guys . I wanna remove the black wing mirror housing of my golf! Anyone got any pics of how to do so ? Thanks .
Re: Wing mirror removal
« Reply #1 on: June 21, 2013, 10:46:02 pm »
All info you'll need is in the "How To Guide Thread". Sticky above your post.  :happy2:
Offline SI-R32
  • -Receive: 126
Offline Gez118
« Reply #3 on: June 22, 2013, 01:47:29 pm »
Yeah I did see that mate , I want to take the black housing off that is on ye door , Not the back of the actual mirror if u get me ? Ha
Offline SI-R32
  • -Receive: 126
Re: Re: Wing mirror removal
« Reply #4 on: June 22, 2013, 02:01:59 pm »
Its all part of the mirror,  or do you mean the bit inside that has the speaker on
Offline Gez118
« Reply #5 on: June 22, 2013, 02:07:44 pm »
Oh right no I don't mean the inside , just the outside I wanna take it off an wrap it in carbon vinyl wrap .
Offline SI-R32
  • -Receive: 126
« Reply #6 on: June 22, 2013, 02:26:47 pm »
in that case yes you need to remove the inner bit where the speakers are then remove 3 screws 2 under the bit of trim i've just mentioned and one hidden under a black plastic grommet, you will need to remove the door card to remove the plug for the mirror, then you can pull it all off and cover it.
fyi it will be quite hard to refit as you need to squeeze it back under the rubber door bit and its a pain in the arse.
Offline Gez118
« Reply #7 on: June 22, 2013, 02:38:59 pm »
Right thanks very much , ill have a go later  :happy2:
Offline SI-R32
  • -Receive: 126
« Reply #8 on: June 22, 2013, 02:53:56 pm »
scroll down a bit of this page and it gives you some idea of what to do
http://www.mk5golfgti.co.uk/forum/index.php/topic,13435.60.html
Offline Gez118
« Reply #9 on: June 22, 2013, 02:57:03 pm »
Perfect , it's always easyer with pictures , thanks for you're help mate
Offline SI-R32
  • -Receive: 126
« Reply #10 on: June 22, 2013, 03:00:13 pm »
no problem
