Author Topic: Headlight switch trim panel removal?  (Read 3339 times)
Offline Kalpesh
« on: July 09, 2013, 04:57:31 pm »
Hi all,
How do you remove the trim panel that holds the headlight switch and headlight adjuster?
Hope that makes sense  :happy2:
Offline doylebros
Offline Kalpesh
Re: Headlight switch trim panel removal?
« Reply #2 on: July 09, 2013, 08:29:20 pm »
Thanks for the reply
Manger to get the light switch out but it's the panel that holds the switch I need to remove
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0ohus9f70ihdmphev1qtts2csp&/topic,19740.0.html
« Reply #3 on: July 09, 2013, 08:31:01 pm »
Theres one screw in the light switch hole.
There is one under the cover on top of the steering wheel
There are two (i think) in the 'roof' of the cubby hole compartment under the light switch
I think thats it
Offline Kalpesh
« Reply #4 on: July 09, 2013, 08:32:26 pm »
Meant managed
Offline Kalpesh
« Reply #5 on: July 09, 2013, 08:38:59 pm »
Cheers for the reply, will give it a go and report back
