Author Topic: How often does the AC need re gassed !  (Read 1347 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« on: July 13, 2013, 07:15:45 pm »
I was wondering how often you guys usually need to re gas your AC, mines is blowing hot air at the moment
Also how much does it cost from vw roughly ?
MK7 GTI - ARRIVING DECEMBER
Offline sanj
  • -Given: 17
Re: How often does the AC need re gassed !
« Reply #1 on: July 13, 2013, 07:25:56 pm »
Around £50 at most car place's such as Kwikfit as i'm sure VW might be double that,mine need's doing too!
Offline skard
  • -Receive: 245
« Reply #2 on: July 13, 2013, 07:35:05 pm »
Find an aircon specialist, you'll find they are cheaper than KwikFit types and will actually do a proper service/vacuum.
I got mine done recently at a local VAG specialist, it was £40.
Offline Gazza747
« Reply #3 on: July 13, 2013, 09:14:55 pm »
Air con service recommended once every 2 years
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline Mk5Dom
« Reply #4 on: July 13, 2013, 09:21:03 pm »
Dealers charge 29.00 for an air con refresh and 79.00 for an air con service.
Kwik fit lulz.  :stupid:
Offline doylebros
« Reply #5 on: July 13, 2013, 09:24:55 pm »
What's the difference between service and recharge?
Offline sanj
  • -Given: 17
« Reply #6 on: July 13, 2013, 09:25:16 pm »
Ok I get your point! :laugh:
Offline torque777
Re: Re: How often does the AC need re gassed !
« Reply #7 on: July 13, 2013, 10:06:41 pm »
Basically refresh is an aircon bomb inside and  a service is a check of gas in system ..tends to be topped up ...if your lucky they will recover complete ..vac it down and then recharge it with a mixture of your old gas and there new gas ...with a sqiurt of pag 100 oil and jobs a good un ...I find every 3-4 years is worth a check ...sooner if you very rarely use aircon as oil will settle in lowest part of system and seals will go dry and leak
sent using my own fingers
Offline doylebros
« Reply #8 on: July 13, 2013, 10:10:27 pm »
Thought all aircon systems  automatically  worked even when off, for the issue you mentioned (oil seals) just at low percentage value?
Offline torque777
« Reply #9 on: July 14, 2013, 06:50:22 am »
The problem is all systems leak ...I'm only talking of a very small amount thats why after a few years the system needs a top up ....if they built the system like your house hold fridge it would remain sealed for years lol
  • -Given: 64
  • -Receive: 48
« Reply #10 on: July 14, 2013, 09:22:54 am »
Cool air con re gas and service it's Is and ill enquire about what what this entails eg if I get the lube oil squirt and vac !
Mines deffo needs done Ive got every recipt from new and no air con work has been carried out so its service time.
« Reply #11 on: July 14, 2013, 10:25:06 am »
Had mine done at work on fri wish was great in the lovely weather we are having
