Along with a mk6 MFSW I'd say they look amazing and change the look of the interior bringing it up to date
The problems being that they cost a fortune and require the ABS pump to be replaced so get tricky and then the programming
then I'd need a CH as mine is mid line atm.
I like the earlier scirocco MFD you had before the newer one although the newer one is banging
@MateyGuv
