Author Topic: Edition 30 baffled sump ?  (Read 1505 times)
Offline Jonathon555
« on: July 22, 2013, 08:48:45 pm »
Just got the oil changed on the ED30, when the sump plug was removed the oil did not spirt out in a single stream as expected .
It just sort of ran down the side of the sump for 5 mins at a reasonable rate.
Is this normal ?
Offline brady88
Re: Edition 30 baffled sump ?
« Reply #1 on: July 22, 2013, 08:54:59 pm »
Did you heat the engine first?
Runs out a lot better when it's hot lol
Offline Jonathon555
« Reply #2 on: July 22, 2013, 09:02:08 pm »
Engine was plenty warm ,  10 mile drive prior to oil change. So should be well up to temp.
Maybe oil was still cold.
It poured out bit like my track car does.
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: July 22, 2013, 09:04:52 pm »
You forgot to take the filler cap off!  :signLOL:
Follow AKS tuning on Facebook
Offline Jonathon555
« Reply #4 on: July 22, 2013, 09:11:54 pm »
Maybe the right pedal needs engaging more LOL
« Reply #5 on: July 22, 2013, 09:47:23 pm »
^^^^ what he said.
I've had a trained mechanic do the same.... A scratch his head to as why its coming out so slowly!  :stupid:
Offline Jonathon555
« Reply #6 on: July 22, 2013, 10:02:10 pm »
^^^^ what he said.
I believe you have hit the bullseye . LOL
