Author Topic: 2.0 TFSI Inlet Manifold Removal, Injector Replacement, Valve Port Cleaning Guide  (Read 9914 times)
Lee M
Hi All,
I've been meaning to get this posted up since I carried out the work in Feb.  Took me a while to put together. :blink:
Guide Includes:
  • Removal of inlet manifold
  • Injector replacement
  • Cleaning the valve ports
  • Changing the RS4 fuel pressure valve (with inlet manifold removed)
I have used the forums for a good few years now and have always found a wealth of knowledge and help from other members so I though it was a good time to do a ‘How To’ for this task and return the favour to the community!
I couldn’t find a guide dedicated the 2.0 TFSI engine in my Mk.2 Leon Cupra (1P - transversely mounted).
The PDF in the link is based on how I carried out the removal, with some of my photo’s and info & images taken from a few other forums/sites plus guides that I came across whilst searching for info.
Allow yourself a bit of time to carry this out without being rushed.  This was my first time removing the inlet manifold, it is a fiddly task that takes a little patience, it took me the equivalent time of a weekend to remove everything, clean the valves and re-install it all.
http://www.scribd.com/doc/156031056/2-0-TFSI-Inlet-Manifold-Injector-Valve-Clean-Guide
I take no responsibility for any damage caused whilst following this guide.
Cheers all
Lee
Offline DanGB
  • Different
This is what I used to remove the manifold..
http://www.goapr.com/support/install/Runner_Flap_Delete/fsi_runner_flap_delete.pdf
perfect. Based on a mk5 golf GTI I guess.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Great work Lee  :congrats:
Now we want to see a review on the newer version of the KW V3!  :P  Many, like we didn't will be unaware of the design improvements compared to the older V3.
Lee M
Will do mike. I'll give it a couple of days of use and get something written up. ;-)
