Author Topic: BSH Catch tank alternative fit.  (Read 38343 times)
Phil Mcavity
Re: BSH Catch tank alternative fit.
« Reply #30 on: August 23, 2009, 09:13:15 pm »
How Much is this kit Dave?? Pm'd you aswell :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #31 on: August 23, 2009, 09:19:32 pm »
^^^ Are you having a blonde moment Steve  :laugh: :laugh: :laugh:
http://www.mk5golfgti.co.uk/forum/index.php?topic=7037
Phil Mcavity
« Reply #32 on: August 23, 2009, 09:21:34 pm »
Sorry, i mis-read when dave said "Alternative", thought he ment a different kit then yours.
« Reply #33 on: August 25, 2009, 07:15:34 pm »
Having visited Dubtek today and 'played' with the actual BSH Catchcan, I think there several places where it can be fitted. As well as where stokeballoon has installed on the near-side, it can also be fitted in the centre and on the off-side.
Here's a pic to show how it can be tucked well away from interfering with other components.
Wherever you decide to position it, it will have to be removed for emptying.
« Reply #34 on: August 25, 2009, 07:36:07 pm »
Is that the std size on e RR?
Offline bacillus
  • -Receive: 453
« Reply #35 on: August 25, 2009, 07:39:55 pm »
Yes it is!   :smiley:
Offline QD MBE
  • -Receive: 102
« Reply #36 on: August 25, 2009, 07:45:36 pm »
Robin,
I looked at that, but with the Air con pipework, the screen wash pipework and the headlight cover in close proximity, with mild vibration, you stand a very good chance of chafing damage to either or several components.
If you are getting short of room adjacent to the battery, then reverse the bracket and drop the can lower.  It will be easily accessible for emptying and further maintenance.  With the right OEM clips it will be virtually OEM style too.
Offline bacillus
  • -Receive: 453
« Reply #37 on: August 25, 2009, 07:48:12 pm »
Robin,
Is your car a MT as I believe there is less free room to play with if you have a DSG box.
Offline QD MBE
  • -Receive: 102
« Reply #38 on: August 25, 2009, 07:52:56 pm »
It is, I appreciate the space must be limited, but there are so many differing ways to fit in and around the battery, I almost fitted it on the bulkhead.  There are some studs there.
I just think that the area around the drivers headlight is very busy, and a pain to get the can sitting right, and prone to vibration induced chafing.
« Reply #39 on: August 25, 2009, 08:07:37 pm »
Good point, Dave - Perhaps I will be popping over to your place and enlisting your help afterall.
Offline candy turbo
« Reply #40 on: August 25, 2009, 09:03:27 pm »
can any one tell me the internal measure of the pipe work supplied with the can cause i want to get some red silicon hose to do mine ?   cheers  guys
Offline QD MBE
  • -Receive: 102
« Reply #41 on: August 25, 2009, 09:06:16 pm »
Hang on.................
Offline QD MBE
  • -Receive: 102
« Reply #42 on: August 25, 2009, 09:11:52 pm »
Right the hose I have left says - 5/8" ID (internal Diameter) 300psi max working pressure.  5/8" is just a shade under 16mm.
Offline candy turbo
« Reply #43 on: August 25, 2009, 09:18:27 pm »
cheers mate , just been looking at silicon hose (turbo and coolant )kits prices  !!!!!!!!!!  might stick with oem , was just an idea  :surprised:
