Author Topic: STOP! Check coolant - Help :(  (Read 3477 times)
Offline Dave_TDI
« on: August 07, 2013, 04:53:46 pm »
Hello :)
Basically every few times I drive the car (not every time) I get a message saying STOP check coolant - see owners manual. Done the obvious and checked the oil and water (when engines cold) and the coolant is fine (just below max) so I'm wondering if its a more serious problem..
I've only had the car a few weeks so not sure how long this has been happening for but it's done it on me about 6 times in the last couple of weeks..
Just wondering if anyone has any ideas in mind that it could be as I can't get to a garage til Sunday and need the car for work :(
The car is a 05 GTI with 70k and FVWSH (last major service 4k miles ago)
Cheers,
Dave
Offline swedishfireball
Re: STOP! Check coolant - Help :(
« Reply #1 on: August 07, 2013, 04:57:22 pm »
If the coolant hasn't dropped then it's usually the sensor in the expansion tank.. the sensor can be 'cleaned' by using a screwdriver but awkward. Easier to change out the tank and quite cheap.
Offline Marc-5-GTI
« Reply #2 on: August 07, 2013, 05:01:31 pm »
I get this also!! I just turn the engine off, squeeze the radiator pipe to get it flowing and then it goes off...
« Reply #3 on: August 07, 2013, 06:02:11 pm »
as mentioned it will be the sensor in the expansion tank
Offline Dave_TDI
« Reply #4 on: August 07, 2013, 06:10:21 pm »
Cheers guys, will get another bottle this weekend, big weight off my mind :)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: August 07, 2013, 07:12:04 pm »
Changed mine earlier this year. £20 for the bottle and literally a 15 minute job :)
