Author Topic: Led Conversions - Should i start?  (Read 3647 times)
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
Re: Led Conversions - Should i start?
« Reply #15 on: August 15, 2013, 11:11:50 am »
if you post them then do you have any spare clocks you can put in your car?
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Re: Led Conversions - Should i start?
« Reply #16 on: August 15, 2013, 11:16:09 am »
I can get a spare set and code it to my car. If I wad to come to you, how long does it take to desolder and solder the led's?
Sent From My Samsung S3
Offline skard
  • -Receive: 245
« Reply #17 on: August 15, 2013, 11:18:38 am »
Sorry to butt in, but I have a midline tdi 962 cluster going if anyone wanted to use them for this purpose, can also code them in to 04-early 06 cars.
Offline reaper7881
« Reply #18 on: August 15, 2013, 11:26:14 am »
The desoldering and resoldering takes about a hour and a half
The most time consuming thing is the actual dismantling to expose the leds
Over all it takes around 2-3 hours if u want the speedo doing not including the midline/ highline screen that alone takes a hour
« Last Edit: August 15, 2013, 11:42:29 am by reaper7881 »
Offline Melkiy
« Reply #19 on: August 17, 2013, 07:22:55 pm »
how much am I looking at if I post just board already out of cluster and speed led left and right replaced in white?
thanks  :smiley:
Offline reaper7881
« Reply #20 on: August 18, 2013, 11:21:05 am »
PRICE LIST:
Speedo not including middle screen = £40
Window switches door lock and mirror controls = £25
Headlight Switch = £20
Heater control panel non climate including econ recirculate and demist buttons= £20
« Last Edit: June 27, 2015, 02:12:23 pm by reaper7881 »
Offline fingerling
« Reply #21 on: August 27, 2013, 05:03:51 pm »
what size do i need for the puddle lights?
Offline reaper7881
« Reply #22 on: August 29, 2013, 10:45:19 am »
I just looked and it looks like the exact same bulb used in the sidelights
« Last Edit: August 29, 2013, 11:21:59 pm by reaper7881 »
Offline reaper7881
« Reply #23 on: August 30, 2013, 03:07:14 pm »
no one?  :party:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #24 on: August 30, 2013, 03:50:36 pm »
I definitely want mine done in white without the screen done. Ill be coming up to midlands end of september to see the in laws so can pop by to you and get them done.
Ill put in a temporary set of clocks so that the original ones are already out to save time
Raz
Offline reaper7881
« Reply #25 on: August 30, 2013, 09:28:39 pm »
no problems  :happy2:
Offline reaper7881
« Reply #26 on: August 31, 2013, 10:13:46 am »
Max brightness
Lowest brightness
« Last Edit: August 31, 2013, 06:56:42 pm by reaper7881 »
Offline RobboGTI
« Reply #27 on: August 31, 2013, 10:46:41 am »
Where are you located
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #28 on: August 31, 2013, 10:56:24 am »
Hes near Huddersfield
Offline reaper7881
« Reply #29 on: September 06, 2013, 12:00:19 pm »
bump
