April 15, 2025, 08:03:13 am
All Things Mk5
Mk5 General Area
Led Conversions - Should i start?
Pages:
Topic: Led Conversions - Should i start? (Read 3653 times)
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Re: Led Conversions - Should i start?
Reply #15 on:
August 15, 2013, 11:11:50 am »
if you post them then do you have any spare clocks you can put in your car?
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: Re: Re: Led Conversions - Should i start?
Reply #16 on:
August 15, 2013, 11:16:09 am »
Quote from: reaper7881 on August 15, 2013, 11:11:50 am
I can get a spare set and code it to my car. If I wad to come to you, how long does it take to desolder and solder the led's?
Sent From My Samsung S3
#RetroRaz -
https://instagram.com/retroraz/
skard
-Given: 5
-Receive: 245
My Ride:
Reply #17 on:
August 15, 2013, 11:18:38 am »
Sorry to butt in, but I have a midline tdi 962 cluster going if anyone wanted to use them for this purpose, can also code them in to 04-early 06 cars.
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #18 on:
August 15, 2013, 11:26:14 am »
The desoldering and resoldering takes about a hour and a half
The most time consuming thing is the actual dismantling to expose the leds
Over all it takes around 2-3 hours if u want the speedo doing not including the midline/ highline screen that alone takes a hour
Last Edit: August 15, 2013, 11:42:29 am by reaper7881
Melkiy
Always Involved
-Given: 3
-Receive: 0
Reply #19 on:
August 17, 2013, 07:22:55 pm »
how much am I looking at if I post just board already out of cluster and speed led left and right replaced in white?
thanks
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #20 on:
August 18, 2013, 11:21:05 am »
PRICE LIST:
Speedo not including middle screen = £40
Window switches door lock and mirror controls = £25
Headlight Switch = £20
Heater control panel non climate including econ recirculate and demist buttons= £20
Last Edit: June 27, 2015, 02:12:23 pm by reaper7881
fingerling
Taking part
-Given: 0
-Receive: 0
Reply #21 on:
August 27, 2013, 05:03:51 pm »
what size do i need for the puddle lights?
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #22 on:
August 29, 2013, 10:45:19 am »
I just looked and it looks like the exact same bulb used in the sidelights
Last Edit: August 29, 2013, 11:21:59 pm by reaper7881
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #23 on:
August 30, 2013, 03:07:14 pm »
no one?
RetroRaz
-Given: 32
-Receive: 194
Reply #24 on:
August 30, 2013, 03:50:36 pm »
I definitely want mine done in white without the screen done. Ill be coming up to midlands end of september to see the in laws so can pop by to you and get them done.
Ill put in a temporary set of clocks so that the original ones are already out to save time
Raz
#RetroRaz -
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #25 on:
August 30, 2013, 09:28:39 pm »
no problems
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #26 on:
August 31, 2013, 10:13:46 am »
Max brightness
Lowest brightness
Last Edit: August 31, 2013, 06:56:42 pm by reaper7881
RobboGTI
Always Involved
-Given: 0
-Receive: 7
Reply #27 on:
August 31, 2013, 10:46:41 am »
Where are you located
RetroRaz
-Given: 32
-Receive: 194
Reply #28 on:
August 31, 2013, 10:56:24 am »
Quote from: RobboGTI on August 31, 2013, 10:46:41 am
Hes near Huddersfield
#RetroRaz -
reaper7881
Always Involved
-Given: 3
-Receive: 4
My Ride:
Reply #29 on:
September 06, 2013, 12:00:19 pm »
bump
Pages:
All Things Mk5
Mk5 General Area
