Author Topic: Potential MkV purchase - Rust spotted  (Read 2512 times)
Offline ondafly
    • My Youtube Channel
« on: August 21, 2013, 08:49:14 am »
Hi Folks,
I'm on the fence about a particular MKV I viewed recently. I noticed a couple of strange rust spots and wondered are they a sign of something worse
Front right sill/arch
Back left rear door
Back right rear door
Offline Beddie
  • -Receive: 76
Re: Potential MkV purchase - Rust spotted
« Reply #1 on: August 21, 2013, 08:51:13 am »
Sadly they are common areas of rust on the mkv  :sad1:
Carbon Grey Edition 35 - Here
Offline ondafly
« Reply #2 on: August 21, 2013, 09:01:08 am »
Is there any particular reason for the rear door pillar rust spots ? also as the car is only 2007 - would VW cover this ?
Offline winrya
« Reply #3 on: August 21, 2013, 09:05:12 am »
You'll probably get a 50% contribution from vw but I'd move on to another car.  The skirts have been badly prepped and sprayed, that paint will flake off in no time
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=5793hefo480ipm06g4g6qcp329&/topic,19740.0.html
« Reply #4 on: August 21, 2013, 09:09:30 am »
The rubber door seals rub the paint work  :sick:
Offline ondafly
« Reply #5 on: August 21, 2013, 09:44:40 am »
The kicker here is, I need a 5 door and the spec of this particular one is excellent, dsg/leather/climate/nav/fsh/low mileage and the remaining ones for sale here (ireland) don't come near that spec.
ah ok, so if repaired, you would need to trim back the door seal ever so slightly.
Offline raymondo1234
« Reply #6 on: August 21, 2013, 09:45:51 am »
wheel arches are a major problem, check all around for any signs of bubbling or early rust
« Reply #7 on: August 22, 2013, 10:44:55 am »
You can buy precut patches to place on these areas
Offline ondafly
« Reply #8 on: August 22, 2013, 02:08:51 pm »
excellent - thanks guys
Offline dmac1969
  • -Receive: 21
« Reply #9 on: August 22, 2013, 08:56:02 pm »
It seems its not only VW that suffered with rust , theres an 07 plate Ford Focus in my works carpark which has all 4 arches and both sill fronts rubbed down and primered due to rust! Surely major manufacturers like Ford and VW should be building cars that last more than 6 years before rusting - this isnt the 70s ffs. Bring back British Leyland.
