Author Topic: Does batt get disconnected for cam follower replacement?  (Read 727 times)
Offline Homer
« on: August 25, 2013, 05:08:58 pm »
Am going to get this done shortly and I have a revo map, if the batt is disconnected it goes back to stock and then the hassle of getting someone to fix the settings. So just wanted to check before booking the job. Thanks.
Offline Bow
Re: Does batt get disconnected for cam follower replacement?
« Reply #1 on: August 25, 2013, 05:09:44 pm »
I never bothered to remove it just make sure you don't open doors whilst pump off
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: August 25, 2013, 06:33:58 pm »
As above, no need disconnecting the battery, just make sure you don't open the drivers door during the process  :happy2:
Offline Meallbhan
« Reply #3 on: August 26, 2013, 04:09:09 pm »
Just open your drivers door window before you start then you can access the inside of the car without opening the door and priming the fuel pump.
