Author Topic: Intake cleaned the RON ECHT method  (Read 15323 times)
Offline martziniuk
« on: September 08, 2013, 01:53:48 pm »
Well I tried the intake cleaning white spirit method today.
I used RON ECHT's method as shown in this vid
I took pictures with the borescope before and after. It was hard to get the scope in but I did my best, here are the results:
Before
After
Admitadly I only got one valve but there is clearly a reduction in carbon. On the road the car feels no different so far but at idle the is no more puttt noise as it ticks over.
Like Ron I think I will now be doing this periodically as its very easy to do.
« Last Edit: September 09, 2013, 08:00:01 pm by martziniuk »
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
Re: Intake cleaned the RON ECHT method
« Reply #1 on: September 08, 2013, 01:55:32 pm »
very good  :congrats: does it feel any better?
have you looked at the Italian tune up?
www.distinctdetailing.co.uk
Offline martziniuk
« Reply #2 on: September 08, 2013, 03:19:24 pm »
Doesn't feel any different so far but I took it out after it was heat soaked from the cleaning. I never had any running issues, I just thought I'd try this method.
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: September 08, 2013, 04:58:35 pm »
Annoyingly an Italian tune up doesn't help one bit on the tfsi engines.
Follow AKS tuning on Facebook
MPS
« Reply #4 on: September 08, 2013, 06:13:23 pm »
Shame, I wonder why not?
Offline Shorty
  • -Receive: 24
« Reply #5 on: September 08, 2013, 06:20:52 pm »
Why don't you take the inlet off and use some seafoam? More work admittedly but alot better job than doing it that way I think and you know it's right.
I'm gonna do mine soon I reckon!
| Mk7 R |
Offline martziniuk
« Reply #6 on: September 08, 2013, 07:57:31 pm »
I've had my intake off twice already, I'm not taking it off again. The point is the tfsi is always going to clog up, this way keeps it semi clean without the time and expense of removing the inlet manifold.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #7 on: September 08, 2013, 08:04:14 pm »
Alex what do you think of RON ECHT's method?
PLANS: Stage 2+
Offline GTI5
« Reply #8 on: September 08, 2013, 08:17:48 pm »
Looks like it shifted a bit of loose build up.
Using Seafoam through the IAT sensor might work from new but I can't see it cleaning those valves.
The Carbon is baked on at high temperature. The only proven method I've seen is cleaning the valves by hand.
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: September 09, 2013, 07:55:35 am »
No way of getting the engine hot enough to burn all the carbon away, and it's direct injection so using a fuel additive won't clean the inlet ports.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: September 09, 2013, 10:30:21 am »
Would a good long Journey not make a difference, if i remember correctly, reading about keeping the revs just over 4500 for about 25mins.
That helps clean/remove carbon from the valves.
Now thats just what i remember reading, dont shoot  :fighting:  me down if I'm wrong...
 :popcornsoda:
Silver is the way !
Offline doylebros
  • -Receive: 310
« Reply #11 on: September 09, 2013, 06:44:21 pm »
Never tried it but this look quick and simple.
Check out this video on YouTube:
Offline GTI5
« Reply #12 on: September 09, 2013, 07:28:52 pm »
Removing and reinstalling the Manifold is fairly involving.
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline doylebros
  • -Receive: 310
« Reply #13 on: September 09, 2013, 07:32:58 pm »
Yes, like most jobs - that method above means it will be clean, proper starting point!
Offline martziniuk
« Reply #14 on: September 09, 2013, 08:01:13 pm »
I went out and took a better after photo which is now added to the original post.
I think this is conclusive proof this method works.
