December 21, 2025, 09:13:48 pm
All Things Mk5
Technical Workshop
front wipers not working
Topic: front wipers not working (Read 7334 times)
ALEXGT382
Can't Read PM's Yet!
-Given: 0
-Receive: 0
September 23, 2013, 08:45:19 pm »
hi guys mk5 gti wiper problems, they dont work from the stalk, but some one has wired a rocker swith down by the fuse box that turns them on. wash works on the stalk, tryed a new stalk and fuses what sends the signal to the wiper unit/ cheers
Degudodger
Just look at my post count
-Given: 53
-Receive: 86
Re: front wipers not working
Reply #1 on:
September 24, 2013, 07:29:16 pm »
Have you tried a new relay?
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #2 on:
September 24, 2013, 07:43:31 pm »
Be a relay or wiring if you tried a known good stalk and a working fuse (if indeed you did replace the right fuse.. it's under the bonnet in that fusebox)
Also wipers not going to work if the bonnet is open (or car thinks the bonnet is open)
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
doylebros
-Given: 44
-Receive: 310
Reply #3 on:
September 24, 2013, 08:01:42 pm »
as above quotes
"wipers not going to work if the bonnet is open (or car thinks the bonnet is open)"
But will show in the MFD - relay favourite.
ALEXGT382
-Given: 0
-Receive: 0
Reply #4 on:
September 24, 2013, 08:04:02 pm »
hi cheers for replys, yeah ive checked the bonnet switch and its fine, wheres the relay, and what sends the signal 2 the motor module as i belve it has a permant live cheers
doylebros
-Given: 44
-Receive: 310
Reply #5 on:
September 24, 2013, 08:19:42 pm »
My approach would be to scan the car first to see what VCDS shows up - then do few testes with VCDS - since the cars been tampered with!
CJS-90
Just Arrived
-Given: 0
-Receive: 1
Reply #6 on:
September 25, 2013, 09:35:44 am »
I'd probably do the same as above ^^
ALEXGT382
-Given: 0
-Receive: 0
Reply #7 on:
September 28, 2013, 07:19:25 pm »
SORTED! wondered why this was doing my f*cking head in, all the strange readings i was getting, got another motor and ound the 1 in there was completly different had 207 writen in black pen on it so f*uck knows wasnt for this car. is ther a turbo change guide about.. many thanks people
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #8 on:
September 28, 2013, 08:43:03 pm »
Glad it was fixed.
A turbo charger guide?
Follow the APR pdf guide for the big turbo upgrade.
Detailing Guide
Wheel Fitment Guide
All Things Mk5
Technical Workshop
