Author Topic: Autobrite snow foam lance - what am i doing wrong?  (Read 2334 times)
Offline Timmyb007
« on: September 24, 2013, 09:50:30 pm »
As above, despite having the lance set full to minus i cannot seem to get a thick foam. Consequently it runs off quickly and doesn't lift any of the dirt etc. It even leaves water marks meaning I end up cleaning normally. What concentration do you guys use? I am using superfoam.   :drinking:
Offline Kinks
Re: Re: Autobrite snow foam lance - what am i doing wrong?
« Reply #1 on: September 24, 2013, 09:52:47 pm »
Use about  1 inch of foam mix with hot water and a splash of washing up liquid
Sent from my GT-N7105 using Tapatalk 2
Offline Timmyb007
« Reply #2 on: September 24, 2013, 09:57:16 pm »
Does it stay on the sides OK?
Offline Kinks
« Reply #3 on: September 24, 2013, 10:02:37 pm »
Water pressure is the next thing. Are you using a good pressure washer!! If so sounds as if the foam mix is a duff
Offline Timmyb007
« Reply #4 on: September 24, 2013, 10:14:34 pm »
What effect would low pressure have? Might try using more mixture next time and/or use a different pressure washer.
« Last Edit: September 24, 2013, 10:22:49 pm by Timmyb007 »
Offline Kinks
« Reply #5 on: September 24, 2013, 10:51:12 pm »
Its the pressure that creates the foam it works on a venturi the higher the pressure the better the mix
Offline Kinks
« Reply #6 on: September 24, 2013, 10:53:25 pm »
When I use mine it will hold for three mins at least and leaves a clear surface when rinced
Offline Horatio
  • -Receive: 39
« Reply #7 on: September 25, 2013, 11:40:02 pm »
Do you clean it after every wash? I found that after two washes the gauze would clog up and the foam wouldn't foam up nicely. I usually soak it in warm water, squirt a bit of cillet bang in the holes and a rinse through  :party:
Offline s3kel
« Reply #8 on: September 26, 2013, 12:35:34 am »
Could be an easy fix ,try running hot water through the lance to clean it as the metal gauge could be clogged up ..have to played about with the black knob adjuster + and - while pressing the pw gun ? If all fails it may need a new metal gauge ..
http://www.detailingworld.co.uk/forum/showthread.php?t=84349
« Last Edit: September 26, 2013, 12:40:35 am by s3kel »
