Poll
Let's see what people are running?
Autotech
APR
Loba
HPFP.com
KMD
Author Topic: What upgraded HPFP are you running  (Read 15956 times)
Offline aarondsg
Re: What upgraded HPFP are you running
« Reply #30 on: October 21, 2013, 08:53:21 am »
Ouch
Is there no Walbro alternative that can be used and mapped in?
R-Tech Power Stage 2+ Edition 30 (LC9Z)
« Reply #31 on: October 21, 2013, 08:54:09 am »
Oh, and that is for an RS3 LPFP. GTI ones may be a little cheaper.
« Reply #32 on: October 21, 2013, 08:58:03 am »
Walbro' s can be used, but IIRC there can be issues with maintaining the right supply. The Walbro works off a level supply whereas the normal LPFP works off a variable supply through a controller. Putting the Walbro through the controller causes issues. It has been done, but isn't as efficient as the OEM+ replacements. :happy2:
Offline aarondsg
« Reply #33 on: October 21, 2013, 09:11:59 am »
Ok thanks for your advice
Looks like I'll have to bend over when I go k04  :sad1:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #34 on: October 21, 2013, 09:13:10 pm »
any chance of a group buy on the loba pump?
Andy I thought you said you'd finished modding your car...  :wink:
oh yeah sorry i have, but as we all know unless you steer clear of this site completely occasional relapses are inevitable  :grin:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #35 on: October 21, 2013, 09:16:42 pm »
Not saying that the Autotech fails, but they don't perform as well as the loba or apr.  The cars I have switched from Autotech to loba have showed gains in power.
I would swap to Loba if a GB price came in at circa £495.00 but not worth paying £500+ for a mod which will only give slight improvement over what have
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bfgibpjtf3dcv6dbjhg12dfc1r&/topic,19740.0.html
« Reply #36 on: October 21, 2013, 09:28:32 pm »
... and a part that wont fail vs one that might.  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #37 on: October 24, 2013, 08:10:11 am »
Its a very noticeable gain.
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #38 on: October 24, 2013, 08:12:11 am »
Are the lpfp expensive to replace?
Around £300 plus around 1/2 to 1 hr to fit max.
Audi dropped the price with the latest revision. £255 inc vat. Needs a blank to use one in a front  wheel drive tank.
« Reply #39 on: October 24, 2013, 08:56:29 am »
Yeah, I think replacing it is a must. At stage 2+ it ensures both the High pressure fuel supply and low pressure fuel supply are both optimal and I'd also recommend doing the RS4 FPRV and even the fuel filter. :happy2:
Offline fuscobal
« Reply #40 on: October 24, 2013, 07:02:00 pm »
Ok Alex, let's say we have one Autotech and one Loba pump. If the logs show both make 130bar all the way as requested by the software, how does the Loba provide a noticeable gain ?
Mk5 GTI 6MT - Revo stage 3
Offline vRSAlex
  • -Receive: 253
« Reply #41 on: October 25, 2013, 08:02:31 am »
I had an ed30 in a few months back running an Autotech. Logs showed it was working fine, but the customer wanted something he could trust 100% so we switched to a Loba. Logs instantly showed the loba reacted quicker to throttle changes, but still ran identical pressure to the Autotech.  Car felt noticeably faster and smoother.
Offline martziniuk
« Reply #42 on: October 25, 2013, 09:57:10 am »
I think it depends on the condition of the pump the Autotech internals are fitted to. I had an old OEM pump which I fitted internals to, then swapped them to a new OEM pump. The difference between them was massive, the new pump found pressure much quicker than the old pump.
I then bought a low mileage APR pump which performed just as well, or maybe a fraction worse than the new pump fitted with the Autotech internals.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #43 on: October 25, 2013, 10:22:22 am »
I've got an Autotech. I bought it "second hand" (tho it was essentially new) for a good price, but if I were to get a 2nd chance I'd go for the LOBA. shame it didn't exist when i had mine fitted
i know in the past Autotechs have been known to fail, BUT it does still seem to be a very VERY rare ocurrence. i agree with berg that you need to weigh up the cost and benefit and for me certainly the APR does not justify its cost. the LOBA imo does but i can understand why berg feels it might not.
« Last Edit: October 25, 2013, 10:26:22 am by sub39h »
PLANS: Stage 2+
  • -Given: 380
  • -Receive: 442
« Reply #44 on: October 25, 2013, 11:01:50 am »
I wouldn't consider the Autotech - Too many people I know who are in the motor trade and whose opinions I respect, don't recommend it.
I have an APR and might have considered the Loba if it had been available at the time. Am totally happy with the APR, so great peace of mind.
