March 13, 2025, 08:37:30 am
All Things Mk5
How to Guides / Troubleshooting
loctite new wheel bearing bolt?
Topic: loctite new wheel bearing bolt? (Read 1141 times)
bower
Always Involved
-Given: 6
-Receive: 4
October 19, 2013, 11:57:23 am »
should i put loctite on the new bolt? also should i use it in the brake caliper and carrier?
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 443
Re: loctite new wheel bearing bolt?
Reply #1 on:
October 19, 2013, 12:30:02 pm »
if your using the same bolts..it won't do it any harm to use it
gttdi build thread
r32 build thread
bower
Always Involved
-Given: 6
-Receive: 4
Reply #2 on:
October 19, 2013, 12:35:17 pm »
im not using the same wheel bearing nut but i am reusing the ones for the brakes
Andy
Admin
-Given: 39
-Receive: 443
Reply #3 on:
October 19, 2013, 12:40:09 pm »
the new bolt for the bearing is blue at the bottom which is thread lock--put a bit on the caliper bolts will be fine
gttdi build thread
r32 build thread
bower
Always Involved
-Given: 6
-Receive: 4
Reply #4 on:
October 19, 2013, 12:44:27 pm »
cheers for reply
mines an aftermarket one so no blue bit, will put some on myself, cheers
All Things Mk5
