Author Topic: New APR K04 Stage 2+ file  (Read 18521 times)
Offline mvb12
  • -Receive: 64
Re: New APR K04 Stage 2+ file
« Reply #30 on: February 19, 2014, 10:52:11 am »
My stage 2+ k03 was below APRs quoted figures on two different dynos but it drove well so it wasn't a problem for me.
what figures did you get if you don't mind?
Offline john a
    • The Veneers Cover Band
« Reply #31 on: February 19, 2014, 07:27:34 pm »
270 bhp and 300 lb ft at stage 2+
Went well enough though.
Offline Sug
« Reply #32 on: July 06, 2014, 08:20:43 am »
I have just had the new APR stage 2+ file loaded on my R
Evoms intake
Loba Motorsport hpfp
BCS downpipe and race cat
Will be getting it dyno'd next week for results
Don't think it will make the 360-70bhp that apr quote would be happy with 340 though as it goes well
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #33 on: July 06, 2014, 12:10:42 pm »
Evoms intake
Which rollers are you going on? I would be interested to see the results as I'm still torn between APR & another big brand...
« Last Edit: July 06, 2014, 12:16:41 pm by TommyR »
Offline Sug
« Reply #34 on: July 06, 2014, 07:21:01 pm »
A local tuner in Durham mate (2wd dyno)
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #35 on: July 06, 2014, 07:32:02 pm »
Ah I see I was hoping it would be on a well known one like JKM or R-tech but it will still be interesting regardless… Especially as my friends S3 did 343bhp 363lb/ft with the v3.4 2+ map on a local rolling road but I’m unsure how accurate it is.
Offline Sug
« Reply #36 on: July 06, 2014, 08:46:28 pm »
Every dyno is different even the well know ones so it's a bit if a lottery tbh. She goes well I know that getting a lower mount fitted so might as well put it on the rollers
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #37 on: July 08, 2014, 06:20:47 pm »
True and that's what counts :happy2:
Offline duncatr
« Reply #38 on: August 08, 2014, 02:09:39 pm »
Evoms intake
What did it make in the end?
My Cupra R (same base) recently made 360BHP on stage 1+ where it was mapped. Had it on a different RR to check and it made 6bhp less.
APR HPFP, Evoms intake. (still not fitted the sports cat downpipe)
Only difference between the 2 days was 4degrees temp change and I fitted red coils and new plugs, plus I had to fit a Sachs uprated clutch and new DMF (manual box) :(
Now considering fitting the down pipe and going for stage 2+ software upgrade.
Offline Sug
« Reply #39 on: August 09, 2014, 11:32:41 am »
Bit disappointed by the RR results (2wd RR )
310hp and 400nm
Any idea?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ah65a2d52me39ba1p3j2foa1dk&/topic,19740.0.html
« Reply #40 on: August 09, 2014, 11:35:33 am »
Stage 2+
Offline Sug
« Reply #41 on: August 09, 2014, 12:14:02 pm »
Yes mate sorry.
Evoms
Loba
Bcs downpipe and sports cat
Apr stage 2+ software
« Reply #42 on: August 09, 2014, 12:24:38 pm »
Do some on road logging.
« Reply #43 on: August 09, 2014, 12:39:45 pm »
Mine made 345 on Marlin motors Dyno (MAHA iirc) and 346 on APRs Dyno.  Before v3.4 and before RFD so hopefully see some gains afterwards
« Reply #44 on: August 09, 2014, 12:51:21 pm »
Take it out and log the boost, fuel rail pressure, N75... as much as you can.
