Author Topic: fault or low tyre pressure???  (Read 1448 times)
Offline golfgti10
« on: November 13, 2013, 11:47:17 am »
the dash board light is on, ive just changed the wheels from 225/45/17 to 225/40/18 would this just be a tyre pressure problem?
if so what psi should I have in the new tyres?
Offline Marc-5-GTI
Re: fault or low tyre pressure???
« Reply #1 on: November 13, 2013, 12:00:40 pm »
It's cause you've changed wheels mate... The PSI will be on the side of the tyre and in the filler cap IIRC
Just hold the tyre set button in for a while till the light goes off  :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: November 13, 2013, 12:00:57 pm »
38/40 I put in the 18's... once pumped, hold down the button until the light goes out. :happy2:
Offline golfgti10
« Reply #3 on: November 13, 2013, 12:02:12 pm »
do I just press the button or do I have the key in or what???
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #4 on: November 13, 2013, 12:03:17 pm »
I've always done it with the car running, but probably does it with just the iginition on.
Offline Marc-5-GTI
« Reply #5 on: November 13, 2013, 12:03:43 pm »
As above
