Author Topic: DAB Aerial  (Read 7677 times)
Offline darrenchambers
DAB Aerial
« on: November 16, 2013, 02:53:09 pm »
Hi all,
I have an RNS510 with DAB which I intend to fit into my Golf mk5, but I'm confused about the antenna. I know that there are various stick on windscreen aerials but I'd like to go for something a bit more oem
I found this on eBay: http://www.ebay.co.uk/itm/Volkswagen-Oem-DAB-Aerial-With-Fakra-Extension-Cable-6m-Rns510-Dab-Rcd510-Rns315-/281207695010?pt=UK_CE_GPS_Accessories_Software_ET&hash=item417948e6a2
Does anyone know if this will do the job ? And what becomes of the FM antenna on the roof ?
Thanks for all your help folks.
Regards,
Darren
Offline john a
    • The Veneers Cover Band
Re: DAB Aerial
« Reply #1 on: November 17, 2013, 09:40:29 am »
I think you need a roof mount antenna in addition to that unit. You'd also be limited to an OE item as well. There is a wide choice of antennae on the market now from functional but not especially attractive internal glass mount to aftermarket DAB/FM made by the same company that make the OE FM aerial.
Offline doylebros
Re: DAB Aerial
« Reply #2 on: November 17, 2013, 10:27:12 am »
The one in this thread (3 plugs) is the real deal:-
http://www.mk5golfgti.co.uk/forum/index.php/topic,73815.0.html
Nav - Dab - Fm
For the same money!
Re: DAB Aerial
« Reply #3 on: November 17, 2013, 08:42:37 pm »
Cheers. I already have a standard FM bee sting, could I use that with this?
Academic really because I really like the look of the 3 in 1 antenna doylebros linked to, would probably look even better in paint.
Offline doylebros
Re: DAB Aerial
« Reply #4 on: November 17, 2013, 08:49:45 pm »
Get in touch with Eddie-NL he had a couple for sale complete with the cables for a cracking price.
It's an relatively easy job since you've already got the bee sting fitted!
Offline john a
Re: DAB Aerial
« Reply #5 on: November 17, 2013, 09:23:01 pm »
No, you'll need a roof antenna capable of receiving DAB in addition to the boot-lid module.
Re: DAB Aerial
« Reply #6 on: November 17, 2013, 10:05:02 pm »
Ok, I think I'll go for this antenna 6R0035501D. Is this an easy fit or do I need to power it somehow?
Looks like about £100+ and so far I workout that x2 fakra extension cables will be required: 1 for DAB and 1 for Nav. There should already be a third cable present for FM. Thing is though, this antenna seems to have x4 cables, is the fourth for a power supply and if so where do I pick up the feed for it?
Thanks guys, much appreciated.
Offline doylebros
Re: DAB Aerial
« Reply #7 on: November 17, 2013, 10:07:48 pm »
Phone is the maroon coloured one not used!
White one is already in the roof lining?
Blue Nav extra cable needed
Black Dab extra cable needed
Both extra cables need run to the head unit.
Re: DAB Aerial
« Reply #8 on: November 17, 2013, 10:13:34 pm »
Thanks, that makes the job easier :)
Wonder why no power is required like most of the 3rd party antennas.
Cheers Gents
Offline doylebros
Re: DAB Aerial
« Reply #9 on: November 17, 2013, 10:20:09 pm »
I'm sure it's supply is from the head unit via the Dab black plug!
The ones Eddie-NL was selling had TV as well.
The trick to fitting them is thin wall 22 mm spanner (short reach) and a mirror to locate the white plug stuck in the roof lining behind the airbag curtain.
Re: DAB Aerial
« Reply #10 on: November 23, 2013, 03:38:48 pm »
Here it is, got it professionally painted, looks great, can't wait to get it fitted.
http://www.flickr.com/photos/49118648@N02/11011223633/
Will fit next week and post photos.
( How the heck do I post pictures ? img tag shows nothin - maybe I ought to rtfm )
« Last Edit: November 23, 2013, 03:43:40 pm by darrenchambers »
Offline john a
Re: DAB Aerial
« Reply #11 on: November 24, 2013, 07:13:13 pm »
Offline doylebros
Re: DAB Aerial
« Reply #12 on: November 24, 2013, 07:43:21 pm »
Looks good painted but what did you do about the mast?
Remember:-
When fitting a 22mm short reach spanner is the job and the white plug is taped to the roof and a read of this May help
http://www.golfmkv.com/forums/showthread.php?t=3508
Re: DAB Aerial
« Reply #13 on: November 24, 2013, 09:02:20 pm »
Cheers, that link will be very useful.
The mast is still in its wrapper, it looks pretty stubby and smooth. The base comes with a bung protecting the thread, left it in for the paint. I did wonder about the contrasting black mast but in fact it looks really smart. Looking forward to seeing it on the car.
Gonna have to wait though - discovered a leak under the engine today :(
Re: DAB Aerial
« Reply #14 on: December 03, 2013, 10:55:51 pm »
« Last Edit: December 05, 2013, 11:01:28 pm by darrenchambers »
