Author Topic: S3 rear brake upgrade done!  (Read 18860 times)
Re: S3 rear brake upgrade done!
« Reply #60 on: January 04, 2010, 12:18:34 am »
So If you have an expensive Big Brake Kit on the front, then  the S3 rears are a good balance?
I am upgrading to S3 Front brakes, but I am gonna leave the rears as standard 280's. Is this the correct balance for S3 fronts? I was going to get S3 rears, but since the car isn't 4wd the S3 rears might be too much.......is that right?  :ashamed:
  • -Given: 380
  • -Receive: 442
« Reply #61 on: January 04, 2010, 11:29:10 am »
I have asked very similar questions in other threads discussing brakes (and possibly even in this thread somewhere) - Experts DaveB and tony_danza both agree that if you have a big brake kit on the front of a GTI/Ed30 and if you also prefer to do your braking before a bend while still in a straight line, then the S3 rears is a very good balance.
I'll be fitting my S3 rear brakes later this month.
Offline paulk
« Reply #62 on: January 04, 2010, 11:55:21 am »
my car has full  s3 fronts and rears and they are bang on....my asrta had alcon 4pots and i must say the s3 set up isnt far of for a fraction of the cost..im in no rush to change these
« Reply #63 on: January 04, 2010, 12:45:25 pm »
But Robin, Would you add S3 rears if all you had up front were S3 fronts?
« Last Edit: January 04, 2010, 12:47:05 pm by monte »
« Reply #64 on: January 04, 2010, 12:56:05 pm »
I believe it would be borderline whether or not to fit S3 rears when you have S3 fronts.
The Cupra makes do with GTI rears and has Cupra/R32/S3 fronts.
If you do trackdays then maybe it is worth it as the S3 rears are ventilated and should help cooling the brakes and pads under heavy useage.
With grippy tyres and a BBK front upgrade, then the S3 rears are definitely worth it :happy2:
« Reply #65 on: January 04, 2010, 01:17:32 pm »
^^^^Cheers John, I thought it was something to do with brake bias and whatnot? :ashamed:  and the fact that the S3 is 4wd so it needs bigger rears than the 2wd golf?
......or I could be talking poo?  :sad1:
« Reply #66 on: January 04, 2010, 01:24:13 pm »
You are right Monte  :happy2:
Although it isn't the fact that the S3 is 4WD, it is more to do with the extra weight in the car due to the 4WD.
Brake bias will alter with bigger brakes, but remember that if you are fitting bigger brakes on the front and leave the rears as they are, you are still altering the bias to the fronts, If you feel that the rear is a little "lively" (ie the rear moves more in comparison to before the upgrade) under braking when the fronts have been changed to the S3's then you can always fit the S3 rears at a later date. :happy2:
Offline Oli
  • -Given: 19
« Reply #67 on: January 04, 2010, 06:47:31 pm »
So no ones had any problems fitting S3 brakes front and rear??
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #68 on: January 04, 2010, 06:53:48 pm »
No  :jumping:
Over the top mod list ;o)
« Reply #69 on: January 04, 2010, 07:23:08 pm »
No x 2  :driver:
Offline chungster
« Reply #70 on: January 04, 2010, 08:14:01 pm »
john....
your new sig makes out like you've becoming a tuner or summat offering all those brands :signLOL:
Offline Poppa Dom
« Reply #71 on: January 04, 2010, 08:26:07 pm »
Only a small part of what Hurdy offers via his on car samples  :happy2:
Offline candy turbo
« Reply #72 on: January 04, 2010, 08:51:10 pm »
i ve just read this thread and did nt even realize the S3 had ventilated rear disc s !!! when you actually add up the better parts on the S3 makes you think they re not really bad value for money  :happy2:
« Reply #73 on: January 04, 2010, 08:59:31 pm »
john....
 :grin:
I may have to alter it a little :signLOL:
Offline gillm
« Reply #74 on: January 04, 2010, 10:24:41 pm »
i have the vwr bbk on mine with std rears and must admit the rear feels like a dog wagging it tail . thats why i have some r32s in the post :)
west tuned gt28 @ 340hp
