Author Topic: Cam follower question  (Read 2849 times)
Offline vRSAlex
  • -Receive: 253
Re: Cam follower question
« Reply #15 on: November 24, 2013, 09:06:28 pm »
Uprated pumps do tend to increase wear, but most follower wear is caused by poor quality oils. I have changed well over 100 followers, but since changing most customers cars to the millers nanodrive oil, wear is almost fully eliminated.  Grade of fuel doesn't really matter as fuel isn't touching the follower.
Check it every service, if the dlc is starting to wear then  just change it, and dump the longlife oil.
Follow AKS tuning on Facebook
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #16 on: November 24, 2013, 09:16:04 pm »
Alex surely there will be extra fuel pressure required to maintain progress on 95RON vs 99RON?  In theory you shouldn't use as much of the stronger stuff as the octane is creating the power needed from less fuel. Hence people getting better MPG on super fuels.
Less fuel means less work for the HPFP and less pressure on the follower?
Probably only makes a very small difference. .   :grin:
« Reply #17 on: November 24, 2013, 09:20:15 pm »
Fuel rail pressure will be met regardless of fuel used. Presuming everything is working correctly.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #18 on: November 24, 2013, 09:23:30 pm »
If more fuel is being injected then surely the HPFP will have to work that little bit harder to maintain pressure?
That's the angle I'm coming from  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #19 on: November 24, 2013, 09:33:53 pm »
A stage 2+ car either using 95 or 98 will still request the same pressure, it's the timing of the car that will be affected.
Uprated pump running 130 bar tends to cause more wear on the follower than a stock pump running 110 bar.
Offline xjay1337
  • -Receive: 377
« Reply #20 on: November 25, 2013, 01:20:35 am »
Here's mine when it was changed, around 92k miles longlife history until my ownership where it's every 8-10k regardless.
