Author Topic: Trackdays and S3 Brakes  (Read 10307 times)
Offline Matto
  • -Receive: 116
Re: Trackdays and S3 Brakes
« Reply #15 on: January 10, 2014, 05:39:16 pm »
Donington is a cracking circuit just let down by access at times,I will have to take the Edition there  :driver:
It sure is. And has the benefit of only being 15mins from me. Shall I let you know when I'm looking at booking one? Trying to get a few down off here. TFSIMike and the likes.
Offline bigeyd
  • -Receive: 31
« Reply #16 on: January 10, 2014, 06:22:48 pm »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #17 on: February 09, 2014, 04:41:55 am »
I now have upgraded to TTS discs (nice weight saving) and DS2500 pads which should be even better.
due to normal wear , I swapped to new pads and TTS 340mm cross drilled discs (my R32 345mm ones were too)
I see no reason why you would fit 345mm discs now other than they are potentially cheaper.
for the TTS disc = Smaller disc = no lip, and they weigh less = win/win
John, could share some details? I didn't know TTS rotors fit. I thought they have different offset.
What about weight exactly?
"You get what you pay for."
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #18 on: February 09, 2014, 08:49:32 am »
I wouldn't mind tagging along as I've never done a trackday in my own car before and is something I want to do this year.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #19 on: February 10, 2014, 01:46:27 pm »
I didnt know either until DaveB the brake guru mentioned it.
340mm instead of 345mm , direct replacement
They are just over 1kg lighter than 345mm discs which is a great given that r32/s3 setup is already a little 'hefty'
Red ED35 5dr DSG
BLOG | BUILD
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #20 on: February 12, 2014, 12:21:36 am »
THX !!   :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #21 on: February 25, 2014, 07:46:01 pm »
on the road feel same as before to be honest, nice progressive pedal with good stopping power, not tried on track yet.
I have cross drilled as i like them, but performance wise theres little, if any difference from solid face (vented) discs
J Hook style slots some on here have too.
Do you have any photos of the parts fitted?  :happy2:
Over the top mod list ;o)
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #22 on: March 05, 2014, 08:43:49 am »
As is usual for the TT they get the good stuff.....
Don't forget regardless of what it says on the side of the box regarding diameter it counts for nothing....radius is everything
The carrier keeps the pad in the same place which is where the work is done. So TTS or R32 discs braking is the same the TT disc is way lighter
I'm doing project mu pads for the R32 caliper, not cheap at £300 plus vat but you could stay out all day with them those together with the TTS discs work very well
Offline flashp
  • -Receive: 65
« Reply #23 on: March 06, 2014, 06:07:49 pm »
Can I ask if the pads that are listed for the TTS are the same as the S3 parts? I have an S3 setup and wouldn't mind the lighter discs. My Ds2500's are quite new and barely any pad material has gone. If I didn't have to replace them that would be good.
Gone but not forgotten :-)
« Reply #24 on: March 06, 2014, 06:09:36 pm »
Just to note that the 340mm discs get left with a 5mm unbraked area on the inside of the discs face.
Offline flashp
  • -Receive: 65
« Reply #25 on: March 06, 2014, 06:12:16 pm »
Bit confused now...did you mean the 345mm has an unbraked area?
I would have imagined that the smaller disc wouldn't have this.
« Reply #26 on: March 06, 2014, 06:15:18 pm »
It could just be the Mintex pads that are slightly smaller. But on mine is has left a small area unswept on the edge nearest the hub
Offline flashp
  • -Receive: 65
« Reply #27 on: March 06, 2014, 06:16:35 pm »
I see. I'll check with JKM (they fitted my parts) and see what the prices are like for these. Thanks for your input.
« Reply #28 on: March 06, 2014, 06:18:40 pm »
camskills... 100 quid for the pads
Offline flashp
  • -Receive: 65
« Reply #29 on: March 07, 2014, 02:36:55 pm »
It seems I need to use the TTS carriers as well (8J0 615 125). Anyone have a lead on a pair of these?  :popcornsoda:
