Author Topic: DSG Problems Some advice needed please  (Read 1465 times)
Offline aarondsg
« on: December 31, 2013, 02:32:48 pm »
Had a low battery just before it packed in things got worst.
Replaced it trouble free since forgot to update thanks for everyone's help
« Last Edit: February 16, 2014, 05:56:45 am by aarondsg »
R-Tech Power Stage 2+ Edition 30 (LC9Z)
Offline DANBOY66
  • -Given: 41
Re: DSG Problems Some advice needed please
« Reply #1 on: December 31, 2013, 02:40:06 pm »
 first thing you need to do is get a scan done
then while they have it plugged in do a basic setting reset on the dsg box http://www.mk5golfgti.co.uk/forum/index.php/topic,24158.0.html
Dan..
Dan..
Offline aarondsg
« Reply #2 on: December 31, 2013, 02:47:42 pm »
thankyou dan .
also some people have said get my dsg oil changed ? as there is no indication as to if it could be low etc.
would anyone reccomend that .
Offline Marc-5-GTI
« Reply #3 on: December 31, 2013, 03:05:56 pm »
DSG oil should be changed every 40k
Check your service book to see if it's been done
Offline DANBOY66
  • -Given: 41
« Reply #4 on: December 31, 2013, 03:12:16 pm »
I am still learning about the dsg box so someone might have a better way
I would get it scanned check error codes if any the delete them
then I would reset the dsg basic settings
drive the recommended dsg basic setting amount to see if it still flashing and so on
then scan again
then if still doing it a trip to vw
Dan..
Offline DANBOY66
  • -Given: 41
« Reply #5 on: December 31, 2013, 03:19:03 pm »
I would not spend any money on it till I have had it scanned
people on here have the software to scan the car for you normally for a drink myself included
here is a list of people http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Dan..
Offline Frodo-anni
  • -Receive: 45
« Reply #6 on: December 31, 2013, 03:28:48 pm »
DSG oil and filter should be every 40k, priced £179 at VW now.
As above, would not do anything until you have it scanned, often the dsg box reset can cure faults.
It may not be the mechatronics unit, but think others have had an issue with the selector/shifter unit (apologise if i have this term wrong).
So you have an idea on price my mechatronics unit was changed 12mths ago under warranty and it was approx £1,850.
mk5 GTI Edition 30 DSG No0391
« Reply #7 on: December 31, 2013, 03:46:46 pm »
I would guess at the selector/sensor. That usually is flagged up by the flashing PRNDS.
Offline aarondsg
« Reply #8 on: December 31, 2013, 03:51:53 pm »
thankyou for all input so far guys i have messaged four of the closest people on the vcds register to me and hopefully can get it scanned
Offline ARV_90
« Reply #9 on: December 31, 2013, 07:25:46 pm »
You say it is fine if you use it in "D" No harsh up or downshifts ? Doesn't sound like a mechatronic issue, Could be the stick itself.... Don't guess the worst all the time get it scanned  :smiley:
