Author Topic: Car idle speed raising on its own and dropping lumpy. Video  (Read 6085 times)
Offline smithyc1987
  • 08 Tornado red gti monza 2s and full leather.
Re: Car idle speed raising on its own and dropping lumpy. Video
« Reply #30 on: January 22, 2014, 08:00:49 am »
Vw are £34 plus vat for pcv and £18 plus vat for pcv gasket.
I cant afford £60 if its not the pcv.
All the tests show pcv working fine.
There was a 12degree difference between acctual engine temp and what it said on vag.com/ temp gauge.
So unplugged temp sensor and engine stopped idling erratically. ??
So i thought i would start here
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=chuqn5m76u5sh7sk0vjpkt4imr&/topic,19740.0.html
« Reply #31 on: January 22, 2014, 09:44:29 am »
Ok... Well do this for me. Find the PCV and take the connector off the intake manifold.... Now blow down that pipe. Report back.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #32 on: January 24, 2014, 07:42:12 pm »
Additionally, is it normally the check valve that foobar's, would it be dislocated in the pipe'per'ridge.
Another solution... book your car into VW for a winter check, iirc it's about £20, you get a free oil or winter pack, both worth about £15... they will give the car a full going over, scanning it etc. etc. and report back with any faults and parts (with part numbers and blown diagrams) of problem areas... which is normally worth about £60 on its own. :happy2:
Offline smithyc1987
« Reply #33 on: January 25, 2014, 01:38:34 pm »
So on my lunch 15 i changed the pcv.
Not had chance to drive the vehicle yet but upon blowing down the pipe from inlet. I couldnt it was closed. But i could suck and it was clear.
To me that sounds like pcv was fine ???
Offline smithyc1987
« Reply #34 on: January 25, 2014, 03:17:07 pm »
Well just got home and about to go for a drive,
Just ripped apart the old pcv and the diaphram had a 1inch split.
Do we think this could be causing the problems  :happy2:
Saintsteve
« Reply #35 on: January 25, 2014, 08:24:48 pm »
Yes, but I told you this ages ago  :laugh:
« Reply #36 on: January 26, 2014, 08:59:37 am »
Yeah. But it's not the PCV Steve....  :wink:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #37 on: January 26, 2014, 09:26:32 am »
 :signLOL:
Offline smithyc1987
« Reply #38 on: January 26, 2014, 10:12:54 am »
Theres no need to be dicks, to be fair all tests showed the pcv to be fine and working im not just gonna replace bits for the sake of it.  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #39 on: January 26, 2014, 10:16:56 am »
Easy fella, it's just a bit of banter.
You're gonna get a bit of sh*t from people who've been practically screaming PCV for over a week  :signLOL:
