Author Topic: Windows always misted up on the inside  (Read 3750 times)
Offline Jap4447
« on: January 19, 2014, 11:18:42 pm »
Recently my windows have been misted up on the inside when Iv gone to the car. I don't drive it all week and Iv looked everywhere for damp and can't find a thing. Anyone know where I should be looking? Windscreen is always the worst!
Offline Human Joist
Re: Windows always misted up on the inside
« Reply #1 on: January 19, 2014, 11:25:15 pm »
Mine has started to do this a little now. Coincidently the pressure switch for the air con failed last month as I got the darth vader noise. Have not changed it over as yet. Don't know if they are linked
Offline shreddedmeat
« Reply #2 on: January 19, 2014, 11:44:23 pm »
Mine was like this when I bought it and obviously was a recurring problem as there was a manky old rag in the drivers door pocket used for wiping the screen. All it took was a bloody good clean - get some Fast Glass or equivalent on it. Not had a problem since. Although if yours is really bad maybe something else is wrong?
'06 Tornado Red 5 door manual
Can help with or fit VCDS / Cruise control / CAN gateways / RNS in North East
Offline Jap4447
« Reply #3 on: January 20, 2014, 07:34:28 am »
I know it's had a windscreen replacement so I'm unsure if that has anything to do with it. Will try giving the windows a good clean and give it a power wash to try and replicate a leak.
Offline rallycross
« Reply #4 on: January 25, 2014, 07:52:23 am »
could just be condensation a couple of my cars are really bad for this, so I tried these silca dehumidifier bags and it seems to work really well
 http://www.amazon.co.uk/dp/B00AZZB5UY
Offline JaseGti
    • Remoteclothing
« Reply #5 on: January 25, 2014, 04:57:41 pm »
Mine suffers as well but not all the time weirdly
But if there is a fix I'd quite like to know
CW is the way forwards
Remoteclothing.com
Offline doylebros
« Reply #6 on: January 25, 2014, 06:20:05 pm »
Start by checking the pollen filter then if that's ok and nothing obvious to your eyes else where as mentioned above then have the vehicle scanned with VCDS  to check and test the 1K0907659 Quality Sensor.
AQS detects polluted air and automatically puts the climatronic on to recycle mode to stop the polluted air entering the cabin and maintaining passenger comfort. Once the air cleans up it reverts back to external air which cause that fault.
Finally, leaving the window open "slightly" for a few minutes greatly assist if you've got carpet mats which are damp!
Offline Leigh200sx
« Reply #7 on: January 31, 2014, 11:46:55 am »
First I would check the pollen filter and put a new one in. Then give the glass a good clean, if it's still bad then there is a possibility it's the seal on the windscreen which is quite common on mk5 golf's. Without going into a long and boring explanation on how and why this happens it does.  If auto glass fitted it then you have a lifetime warranty.
Offline Broomy
  • -Given: 18
« Reply #8 on: February 03, 2014, 07:32:19 am »
Had terrible bother with misting up windows when I bought the car for around a week & noticed a post on here saying before you shut off the engine have the air blower open at feet not windscreen. Haven't had a bit of bother since I started doing that :)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #9 on: July 29, 2014, 04:05:58 pm »
I know the thread is old but just for people using the search...
My screen was fogging up very badly so I put washing up liquid on a microfiber towel and applied it to the inside of each window. Left it for a few minutes to dry up slightly and then remove with another microfiber cloth.
This leaves a hydrophobic layer on the screen so the condensation (gaseous water droplets) can't actually adhere to it.
It usually lasts about 4 months before you need to reapply.
I also picked up about 100 packs of silica gel from eBat shipped from Hong Kong for a few pound and dotted these around the place for a few days before removing. Not sure how effective this was though.
