Author Topic: door module  (Read 1597 times)
door module
« on: January 25, 2014, 02:06:23 am »
my alarm started going of on my car tonight and fearing the worst that some bodwatrying to Nick it I rushed out side andnoticed my led indicator for the alarm is not working  so pressed the fob and the doors open except the drivers door and now noticed the window  switchs and fuel flap doont work or light up...Had it scanned poss be door module is this it
Offline SteveS
Re: door module
« Reply #1 on: January 25, 2014, 01:11:09 pm »
When i had your problem it was situated in drivers side door, looked exactly like that. VW replaced to fix.
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline Biff
Re: door module
« Reply #2 on: January 29, 2014, 09:47:49 pm »
Mine was in for a service last week, similar issue with the door module showing a fault and had one or two issues with the alarm. Turned out to be a flat battery. Not enough charge to unlock the door.
Offline SI-R32
  • -Receive: 126
Re: door module
« Reply #3 on: January 29, 2014, 10:05:04 pm »
To answer your question, yes that is it, comes as a complete unit and as long as you don't have folding mirrors can be found quite cheaply all over ebay as there all standard except if you have folding mirrors
Re: door module
« Reply #4 on: January 29, 2014, 11:07:58 pm »
does it come part as the window motor or bought on its own
Offline SI-R32
  • -Receive: 126
Re: door module
« Reply #5 on: January 29, 2014, 11:21:47 pm »
The black box and motor are all one part, don't get me wrong it can be split but no one usually sells like that, virtually all 2nd hand units are motor and black box.
Re: door module
« Reply #6 on: January 29, 2014, 11:25:02 pm »
Thank you for the advice Si-have an account with tps at work ,will ring themto see if i can buy it seperate but found one on e-bay £45,will cheeck also the wiring hasn't snapped in the harness first :happy2:
« Last Edit: January 29, 2014, 11:30:06 pm by maxitrol »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: door module
« Reply #7 on: January 29, 2014, 11:38:54 pm »
You can't buy the black box, you have to buy a complete motor
Cluster and Key coding
Location Great Yarmouth
