Author Topic: ABS PROBLEMS NEED HELP  (Read 1593 times)
Offline Andy1994
« on: February 01, 2014, 08:49:15 pm »
changing springs on car and found abs sensor broken, so replaced the sensor, now i am getting code for n/s/f wheel speed sensor mechnical failure intermittent. When you start the cra abs light is always on speedo reads iratically eg can do 60mph in first gear although only around 30mph, but once driven for a fw minutes the traction control light and tyre pressure light also come on and speedo goes back to normal.Is this a wiring fault or a faulty wheel bearing?
Offline doylebros
Re: ABS PROBLEMS NEED HELP
« Reply #1 on: February 01, 2014, 08:54:07 pm »
Recheck your work and if all is ok you'll need to scan it with VCDS.
Look on here to see if anyone is close to you
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline Andy1994
« Reply #2 on: February 01, 2014, 09:13:07 pm »
ive scanned with vcds after fitting the sensor and clearing the codes, the code is
00283 - ABS Wheel Speed Sensor; Front Left (G47)
             003 - Mechanical Failure - Intermittent
Offline Andy1994
« Reply #3 on: February 01, 2014, 09:13:59 pm »
car was fine until i replaced the sensor as the casing was broken
Offline doylebros
« Reply #4 on: February 01, 2014, 09:19:59 pm »
Remove the sensor you fitted and recheck it for contamination, if all looks ok You'll be able to test that sensor in the advanced measuring blocks - Jack that wheel up and then spin it whilst viewing it on VCDS.
This may help
http://m.youtube.com/watch?v=9eLKUoEBlsk
« Last Edit: February 01, 2014, 10:18:31 pm by doylebros »
Offline doylebros
« Reply #5 on: February 01, 2014, 09:54:07 pm »
Is the sensor OEM or pattern part?
Offline Andy1994
« Reply #6 on: February 02, 2014, 02:11:09 am »
not genuine was a cheap sensor
Offline Andy1994
« Reply #7 on: February 02, 2014, 02:36:06 pm »
Found corrosion on the multiplug, if cleaning it up doesn't help do vw sell a repair wire?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: February 02, 2014, 02:53:07 pm »
Do you have a photo of the plug?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #9 on: February 02, 2014, 02:58:28 pm »
VW sell a repair wire for the New Beetle so I would presume they also do for your vehicle.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Andy1994
« Reply #10 on: February 02, 2014, 03:04:37 pm »
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #11 on: February 02, 2014, 03:20:36 pm »
You can get a new plug and repair wires from VW but i don't have the part numbers.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #12 on: February 02, 2014, 03:29:21 pm »
Short term I'd try a squirt with something like this. Then use some silicone grease on the connector to keep water out and avoid further oxidation. Might get you away. Deoxidiser and silicone grease are always in my tool box.
Offline doylebros
« Reply #13 on: February 02, 2014, 06:16:12 pm »
Look here
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1729&ein=2007&f=614&hauptgr=1234567890&hg=9&grf=092700409&bf=92700&hgug=927&ug=27&parent_id=2766027&detail_id=2766062
This shows the online link to what you want.
If I'm correct you want :-
28 - 357 972 740 E - single wire seal - £0.55
27 - 000 979 131 EA - £2.82 for bag of 5 connectors
26 - 8T0 973 702 - housing connector - £6.02
Offline doylebros
« Reply #14 on: February 02, 2014, 06:20:43 pm »
Sounds the job - must get a tin to try but the price!! - cheaper anywhere else?
