Author Topic: New Car Battery Advice  (Read 14607 times)
Kam88
Re: New Car Battery Advice
« Reply #30 on: January 18, 2015, 06:48:03 pm »
I always go to Halfords for battery bit more ££ when buying but have lots of stores and if there is issues they always change it over without any problems. Had one from euroscrapparts and wow the headache of swapping it over was just crazy.
Liam0205
« Reply #31 on: January 18, 2015, 07:15:09 pm »
Ordered a varta e44 today from tayna , cost £65 inc delivery with a 5 year warranty  :happy2:
Offline Flyingscotsman
« Reply #32 on: January 18, 2015, 07:42:15 pm »
That's a really good price! About £28 cheaper than the Bosch S5 008 I bought - looks very similar & has an identical spec !!!
same factory ???
« Reply #33 on: January 18, 2015, 07:42:53 pm »
That is a good point :happy2:
Liam0205
« Reply #34 on: January 18, 2015, 07:56:24 pm »
same factory ???
Possibly, some of the comments earlier in the thread suggest the specs are similar  and I know another Eddy owner who bought a Varta and hasn't had any issues
« Reply #35 on: January 18, 2015, 07:59:30 pm »
VARTA E44
Voltage   12 Volts
Capacity   77 Ah
CCA   780 A
278 mm x 175 mm x 190 mm
BOSCH S5 007
Voltage - 12V
Capacity - 74Ah
CCA (EN) - 750A
278L x 175W x 175H
BOSCH S5 008
Voltage - 12V
Capacity - 77Ah
CCA  780A
278L x 175W x 190H
Offline doylebros
« Reply #36 on: January 18, 2015, 08:03:16 pm »
Why not fit the TPS battery they've got this one ?
Part number - JZW 915105A - 72ah - £55ish inc vat.
Offline andyp
« Reply #37 on: January 20, 2015, 11:38:10 am »
Had mine checked this morning and have been referred to see a auto electrician as sometimes the wire which sends the charge gets corroded.   So this may be the cause of my issues
« Reply #38 on: January 20, 2015, 12:09:28 pm »
If your current battery is over 3 years old the first thing I'd do is replace it.  If it's less and under warranty take it back.
Standard car batteries are really only good for about 3 years. Depends on how they are used, if left for a long time in discharged state they will go bad quickly.
The cost of getting someone to look at the electrics will probably cost more than a new battery.
Liam0205
« Reply #39 on: January 20, 2015, 07:16:17 pm »
If anyone was  thinking of using Tayna I would strongly recommend them
Ordered Sunday and delivered today, great service
Offline dajonic
  • -Given: 17
« Reply #40 on: January 20, 2015, 08:50:19 pm »
Another vote for Tayna. High spec Varta battery cheap price and delivered very quickly within an hour delivery window. Replacing the original battery after 8 years and 156000 miles so sticking with what came from the factory.
Offline dajonic
  • -Given: 17
« Reply #41 on: January 21, 2015, 11:56:54 am »
Just swapped batteries earlier. Checked the old battery again and it holds a full charge and knocking out a healthy 12.56 volts but was starting to lose its cranking power. New battery in and starts first time at turn of the key. Result.
Offline Panthera
2007 Blue Graphite Golf GTi
« Reply #43 on: February 08, 2015, 11:47:11 am »
Yes that is the exact one I have just fitted; it is cheaper on Amazon (but also sold by ECP)
http://www.amazon.co.uk/Bosch-Car-Battery-Type-096/dp/B005XVUQ6Y/ref=sr_1_1?ie=UTF8&qid=1423395867&sr=8-1&keywords=s5+bosch+096
However, others found a similar Varta battery cheaper from other suppliers - see thread above
Offline driver rider
  • -Given: 18
« Reply #44 on: April 15, 2015, 03:50:38 pm »
Hi guys my battery has died so just wanted to be sure that the battery I'm after is the s5 type o96.  I'm only interested in Bosch.
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
