Author Topic: Rain sensor adhesive  (Read 4601 times)
Offline marko
« on: February 04, 2014, 11:51:27 pm »
Anyone recommend any particular type of glue to stick a rain sensor mount to the windscreen on mk5 golf??
Gonna have a go at the retrofit of auto dim/rain sensing mirror at the weekend.just found the kit has no adhesive or glue in it.
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline skard
  • -Receive: 245
Re: Rain sensor adhesive
« Reply #1 on: February 05, 2014, 01:18:13 am »
There is an OEM glue, but I don't know the current part number.
There is a couple listed here but they may be outdated http://www.myturbodiesel.com/wiki/rain-light-sensor-retrofit-and-installation-vw-diy/
I did this in our Tiguan but opted to crack the windscreen, and paid the excess to get a new one with a pre-mounted sensor holder in the right place.
I doubted any Loctite type tubes would hold it, the frame and mirror unit is heavy.
Otherwise I had a local independent glass fitter who offered to fit the frame for me with the proper adhesive. If you have a local windscreen place it would be worth dropping in and asking them if you can get some/maybe fit it for you.
Offline doylebros
  • -Receive: 310
« Reply #2 on: February 05, 2014, 06:01:01 pm »
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #3 on: February 07, 2014, 09:28:38 pm »
just found this on the bay
http://www.ebay.co.uk/itm/181275826598?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
is this the actual thing that holds the sensor to the screen?
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline skard
  • -Receive: 245
« Reply #4 on: February 07, 2014, 09:35:16 pm »
The sensor is not glued, I take it Marko is asking for the adhesive to stick the metal frame to the windscreen.
Have a look here, the sensor slots into the metal clip and then a spring on the back of the mirror unit compresses it in tight
http://www.aliexpress.com/item-img/OEM-Original-Auto-headlight-switch-Rain-Light-Wiper-Sensor-Anti-glare-Rear-View-Mirror-For-VW/1583183414.html
Offline SI-R32
  • -Receive: 126
Re:
« Reply #5 on: February 08, 2014, 07:07:27 am »
If its just a standard mirror back without rain sensor then its D 000 703 A1 which is set of glass metal adhesive
If you have the rain sensor then you need D 180 KD2 A1 which is a 2-pack polyurethane adhesive
1st ones about a Tenner 2nd about 25 quid.
Offline marko
« Reply #6 on: February 09, 2014, 10:34:42 pm »
Thanks guys..
Its the D180KD2A1 that i want...
