Author Topic: Will I need a new DMF??  (Read 1915 times)
Offline J6JCC-GTI
« on: February 05, 2014, 05:24:36 pm »
My clutch is slipping and I'm wondering if the dual mass flywheel will need replacing when the new clutch is fitted? The cars done 60,000miles and doesn't seem to have a problem with the flywheel as far as I'm aware(no noise or virabtion).
Insta: jclarke2792
Offline skard
  • -Receive: 245
Re: Will I need a new DMF??
« Reply #1 on: February 05, 2014, 05:27:35 pm »
I think at 60k it is false economy not changing the DMF at the same time as a clutch kit.
Offline J6JCC-GTI
« Reply #2 on: February 05, 2014, 05:35:04 pm »
I think your right, it's gunna cost me an extra £200 but I think it's worth it, if not I'll be taking the gearbox off again in six months when the flywheel drops to bits!
Insta: jclarke2792
Offline skard
  • -Receive: 245
« Reply #3 on: February 05, 2014, 05:52:01 pm »
The last owner of my car had an uprated clutch in that got ruined by the flywheel as it reached the end of its life, ended up replacing both.
I've always done both on my cars, you will feel better having it done I am sure.
Offline john87
  • -Receive: 53
« Reply #4 on: February 06, 2014, 02:50:43 pm »
I've just replaced my clutch at 28k and the VW specialist told me that the flywheel was fine and not to bother replacing. All depends on the mileage and how the car has been driven, if it has been tuned etc.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: February 06, 2014, 03:47:41 pm »
At 60k miles its a false economy to not replace the DMF if you are fitting a new clutch.
